Go Back   HeliFreak > R/C Electronics Support > YGE
YGE YGE ESC Support and Discussion
Old 02-25-2012, 07:59 AM   #1
bj660raptor
Default a programming option?
Hi I was wondering during programming can you choose 2 parameters for the start up speed? for instance can i choose heli middle and then plane fast,would that then be the start up speed then throttle response? thanks, as of right now i just have heli middle so i wanted to see if i can get better throttle response than I have now?
Trex 700DFCHV,helijive,vbar 5.2 pro
Goblin 500 bls 153,bls 251,jive 100,pyro 600-12 20t pulley,mini v 5.3 pro
Rockin TP 65c and 70c and Futaba 8FGS.
Pilot Brandon J.
bj660raptor is online now        Reply With Quote
Old 02-26-2012, 07:10 AM   #2
snemi00
You can only have one throttle response selected. With the vbar governor we have two throttle responses like you are talking about.
I am assuming the reason you asked this question is because the throttle feels weak in flight and the headspeed recovers slowly. You must be running a throttle curve on your radio and not using the YGE governor function.
You may be used to running a Castle esc with a flat throttle curve or similar. The YGE is really meant to be used in governor mode and has an amazing quality governor built in. The governor will control your headspeed solidly and this is why there is no need for throttle response programming.
Team RotorQuest / SAB Heli Canada
SAB Goblin 700 YGE160HV, Goblin 770 YGE160HV Scorpion 4530 14s, Goblin 500 YGE120, Logo 700 XXtreme, Protos Mini stretch 6s
snemi00 is offline        Reply With Quote
Old 02-26-2012, 09:36 AM   #3
bj660raptor
k its on my logo and yes flat curves, i am running a 70% curve idle1,and a 85% curve in 2, when i tried to set the gov on when i hit idle2 i thought the head was going to explode and the esc came down beeping,can you give me some starting points with the yge gov programming,be as in depth as you can,ireally wanna get this right and thanks for your help.
Pilot Brandon J.
Old 02-26-2012, 08:54 PM   #4
bj660raptor
k so i went to electrorc and there is a programming article and i programmed it and it seems like it works in idle 1 and normal flight but when i go to idle2 the headspeed goes 100% even with an 80% flat curve. When i program it i use normal mode to program it i have a linear throttle curve 0 to 100 so should i program it with idle2 and throttle hold?
Pilot Brandon J.
Old 02-27-2012, 12:07 PM   #5
snemi00
Make sure you set the stop(low throttle) and full speed (100% throttle) with the program card and the esc beeps when you do it. A linear 0-100% curve is fine to setup with.
Old 02-27-2012, 02:09 PM   #6
bj660raptor
yeah the throttle is linear in stop and full setup seems like the gov in norm and idle one but switching to idle 2 i dont get that smooth next gear transition it just slams into idle 2 with a ridiculous headspeed,whats going on with that?
Pilot Brandon J.
Old 02-27-2012, 10:15 PM   #7
bj660raptor
ahhh to hell with it,im gonna go vbar gov
Pilot Brandon J.
