| YGE YGE ESC Support and Discussion |
I have the 90HV and setting up the Synergy. I did couples of hovers today but after playing with the bar settings, i always have the 6 beeps error code.
How could i reset the 6 peeps error code when i power up the ESC? Is it OK to fly with the beeps? Other than that, It starts fine. ![]() |
#2 | |
Trouble shooting: 2 Beeps/flashes: Under-voltage identification 3 Beeps/flashes: Temperature rise warning 5 Beeps/flashes: Receiver signals failed 6 Beeps/flashes: start up failed The ESC signals any error that happened during flight acoustically (motor) and optically with a blinking LED code. Errors 2 and 3 are signaled after motor stop, but aren’t stored as long as the ESC didn’t cut off completely (low voltage / temperature warning). In case the error led to a complete cut off, then it is not cleared by a tension RESET. The deletion can take place only on purpose by connecting the battery with the stick at full power and/or with 100% throttle pre-selection (throttle curve), and disconnecting it again after the interval beep. Please you leave the stick at full power, while disconnecting, otherwise you activate the RC-Setup. Likewise the errors can be cleared by activating the ProgCard. With an activated brake, the error is only signaled after a tension reset or in wind milling position.
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025 Gaui X6 vbar silver 5.3 YGE120HV 700mx ElektroRC.com field rep (YGE, MSH, LAHeli) |
#3 | |
Hi Joe
Yes I am getting a "6beep/flash" after plugging the 12s lipos. I did 3 flights this morning and can not get rid off the error code. Quote:
Question: How do you reset the ESC with the progcard? Thanks for your feedback Daniel |
#4 | |
This is an error in all YGE's. I first thought they were awsome, and they are If you dont use vbar bailout and get used to using the progcard to reset an error message that is there for no reason at all ![]()
Logo 600 - PD-Scorpion 4225 470kv+vbar gov/YGE120hv/Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+ Hobbymaniac Teampilot |
Hello Velocity
ok, i pluged the progcard and reset the error. Last time i forgot to plug the lipo.... Now the 6 beeps are gone and i only have one beep after initialization. I assum one beep/flash is fine ? Daniel |
#6 | |
If you are getting the error after you have reset it, i would not fly as there is something wrong. Take out your esc and look for frayed cable...bad motor bullet, esc side and motor etc. You dont want to fly if you keep getting this error!
#7 |
Nothing wrong with it. It can also be triggered by connecting the lipo to slow. Maybe that happened.
#8 |
If you are getting the error because you connected your lipo too slow then I would send back your YGE. I have plenty of them to know this isnt true. in all honesty it sounds like something is wrong with your YGE...maybe a bad mosfet...because that error only comes on when it fails to start motor after it receives throttle signal and wires are disconnected.
#9 | |
Gaui X5 Formula,helijive,vbar 5.2 pro,align hv servos Goblin 500 bls 153,bls 251,jive 100,pyro 600-12 20t pulley,mini v 5.3 pro Rockin Pulse 45c TP 70c and Futaba 8FGS. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Pilot Brandon J. |
#10 |
Sponsor is treating me with the new Scorpion Commander.
#11 |
Another reason for the six beeps is when rotor gets stuck, ie in a crash if one is not fast enough to hit TH or during spool up if rotor starts and is blocked by hand.
#12 |
Im trying to tell that theres nothing wrong with the escs and I have figured out what causes it. When I connect the prog card I always disconnect 2 motor wires. If you change something, like pwm and disconnect it and connect the motor wires again, you will get the 6 beep error. Not just on my esc but on every YGE esc I have seen.
#13 |
I seem to be stuck in this mode and cannot get out of it
When originally setting up I didnt have the motor plugged in which may have caused this Now I am stuck in this error and cant get out. http://www.youtube.com/watch?v=OZLHP...ature=youtu.be
PRÔTOS 500 CF - BeastX MCPX |
#14 |
Yes, setting it up with motor wires loose will trigger it. Just connect the progcard with the motor wires attached powerup and disconnect. The error is gone now.
