| Beam Avantgarde 600 Beam Avantgarde 600 Support Forum |
Guys,
I'm buying a new Heli and I'm limiting my options to the Fusion 50 and the Beam 600, I really can't decide, and the reason that I'm a bit biased towards the Beam is the gears stripping problem with the fusion, I need your help on this one guys I'll be using the below equipment:
Furion 6 from Miniature Aircraft
Dany Synergy E5 in the works Furion 6 Flybarless, Skookum 720 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Beam E4(v1) FBL, Skookum 540 |
I don't own any 600 helis so can't really give you advice on which to choose. But I think I know which one you want, posting in the Beam forum and all.
When you have read all the facts and made up your pros and cons list and still can't decide. Just go for the gutt feeling. Pick the one you want. The one you feel is coolest for you to have. Thats what I would do anyway
Beam E4, MSH Protos, Trex-250 |
Wouldn't putting JR servos on an Outrage Heli kind of be blasphemy or something?
The final answer is Beam E6 : All new class 600 EP
It's very light weight but powerful, just use head speed 2200 - 2300 RPM it's enough to fly hard 3D. My config : - Beam E6 - Cyclic Servo Nexus 616MG HV - it's nearly the same as JR DS8925 HV (I test with my 7HV - wonderful prformance !!! It's very good HV servo) - Motor Compass 6HV 540KV - powerful with low power consumsion, it's the champion of class 600 - Hobbywing Pentium 100A HV - It's powerful more than ICE2 and easy to config. Use high timing when use with Compass motor 6HV 540KV - Rudder JR DS8900G - I love it and use with Vibe Nex 50 / Beam E6 / Compass 7HV - Beast X ver 3 - when use with Beam E6, performance of Beast X is so amazing. I think ratio of Beam E6 is correct and same as Logo 600 - Gryphon HV BEC - better than CC BEC Pro a lot - Gryphon Dual Step Down - New Gryphon Blade 615mm - AMAZING performance - Battery : Zippy 2600mA 40C 12S - can fly 3D 4:30 minutes / hard 3D 3:30 minutes with non-stop crazy flying Comparing with Trex 600 - it's more solid and light weight Test first flight : Last edited by w_prasit; 03-08-2012 at 12:10 PM.. Reason: added clip |
#6 |
Ive had both, the Fusion was not very good quality at all, things had trouble ligning up, holes in metal not drilled properly, threads wernt cut deep enough etc, i weighed the main and tail grips as i was building and both the main grips were different weights and so too were the tail grips.
The Quality of the Beam is VERY impressive, everything fitted up nicley and the machining quality and carbon is excellent. Flew much nicer too, very smooth machine, AvantGarde is in a higher class of Helis without a doubt. GET THE BEAM! |
