| mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions |
Well I promised the review by today and here it is. This frame was sent to me by Xtreme and while not "official" they call me a sponsored pilot. Now with that out of the way.
The frame needs assembly and to assemble it you must partially disassemble the frame to install the pieces. The CF is the same thickness as their CF landing skids. The frame is quite stiff despite it looking "weak". There is no flex or twist in the frame and I could not get the boom to slip out by hand. An aluminum boom block is on the way, however, that is what they tell me. The frame is rather wide as the servos mount nearly flush to the frame sides, they do not have stand offs like other frames. I will be putting in a Spin 16300 soon. Enjoy the 1080p video with pics at the end.
Blade 130X Xtreme-Production
Blade mCP X (Bl) Blade Nano CP X Prôtos 700 |
Nice review
Great review. Could you touch on the strength of the boom mount. I heard you say that it wouldn't throw the boom but that isn't my concern. Im worried about side to side strength. Thanks a ton and agian great review.
I'll add another video when I get home but there is no movement if memory serves me right.
Thanks for the review.
You mentioned the canopy pins installed from inside the frame out, so if they broke, especially the ones at the AR, you have to unscrew to upper bearing block to install the pins? If that's the case, that's not a good design.
Blade mCPX | TRex 550e | TRex 500DFC | DX8 Helibug TRex 600DFC 17T, HC3sX, Hanson 26 Pro Plus, GV1/SG, Century V5 Helix G700 17T, HC3sX, CY F270, GV1/SG, Century V2, Generator |
#6 |
My HF Map location Join Date: Apr 2011
Location: Burnaby British Columbia - the most expensive place on earth!
dumb question..... Got lots of those... but..
what is Xtreme's www address? Thanks for the review Sym.. happy flying. |
#7 | |
Here http://www.xtreme-production.com/xtr...id=39&Itemid=9 |
#8 |
It's only 2 screws I believe because if you remove 1 screw from each side of the bearing block, it will swing up and out of the way.
#9 |
kewl, I just bought one. Gonna slap a spin 16300 in there and see what happens.
#10 |
I unfortunately can't take a video but the boom block itself has no movement. With excessive force you can get about a mm or so of side to side movement of the entire frame rear of the bearing blocks, but the MicroHeli frame has a lot more movement rear of the bearing blocks. I just compared the 2 side by side.
#11 |
What stops the tail boom block from pivoting up and down on the 2 screws in the side plates? If you break a canopy pin do you have to buy replacement pins or can you make them from cf rod like the MH frames?
Lynx Heli Innovations team pilot. Mavrikk field rep.
#12 | |
http://www.clubheli.com/Spare-Parts-...me_p_3773.html
#13 | |
I have just transferred from a RKH frame to the Xtreme frame. I like that the main carbon fibre frames are identical and that the inner plastic pieces that hold the servos and the like deal with the skewed servo locations and are protected by the outer frame. This seems like a better arrangement to me. I have been unable to get a pair of Xtreme skids in Oz so I have attached my Xtreme boom supports to the lower frame screws. My warning and biggest gripe is with the holes in the CF frame which are a little too small. I found that the screws screwed into the CF frame before they bit into the plastic inner frame. This meant that you had to keep screwing to ream out the CF and screw into the plastic. Unfortunately, on a few occasions I ended up stripping the thread on the plastic components. You can even be super careful with the screws or maybe open the holes in the CF frame to a clearance fit - maybe 1.3mm. Other than this it went together easily. The boom mount seems good to me, especially with the boom supports. It is quite flexible so I think it will be very forgiving in a crash. The canopy pins are interesting. Firstly, they are quite large and it was difficult to get the canopy on. It is unlikely to fall off. Secondly, they are made of a very flexible plastic which flexed a lot when I put the canopy on. Be very careful. I used a little oil on the pins to help. I imagine that Xtreme have chosen this material so that I flexes rather than breaks during a crash. Time will tell if this is a good idea. I have crashed once and bent a microheli aluminium main shaft but the frame and canopy is ok. My setup is: Xtreme frame Spin 16,300 motor The Steve XP12 (only esc I had spare) 550 mah batteries from SR120 Xtreme swash (don't like, always throwing balls) Xtreme head RKH blade grips 2mm solid boom Astroid Designs twin inline tail holder with coreless motors KBDD main and tail blades. Xtreme canopy Cheers, Ibs Sent from my GT-I9100 using Tapatalk
450 Pro hybrid, DFC, ZXY-S, 3S Blade 130x, HP08 Blade Nano CPx stock |
#14 |
Does anyone else have a definitive good or bad response to what they think about this frame? I am intersted but would like to see more reviews.
Stretched CarbonFbl Protos 500, Ikon, Scorpion 900kv, Castle Ice 75 Blade MCPX, MQX DX8 |
#15 | |
As it stands now, I am kind of so-so about it. Its def rugged and fairly structurally sound, but my only gripes are the flimsy canopy mounts and that tail boom mount. Also be careful with some of the delrin you screw into. Doesn't take much to strip some of the screw holes.
Tarot 450 Pro V2 DFC 6S - Scorpion 2010 - YEP 45A - Hitec 5065 - Hitec 5084 - Robird G31 Trex 500E DFC - Castle Vertigo 1800 - Castle ICE75 - DS510M - DS520 - AR7200BX MSH PRÔTOS - Scorpion 880 - YGE 60A - Futaba 9650 - Futaba 9254 - AR7200BX |
#16 | |
#17 | |
#18 | |
I like the adjustable metal motor mount. Only way your replacing canopy pins is to remove the side or all screws but one and pivot on that one screw. I had several screw that never tightened. Never even got the chance to strip them. They just screw in and spin. Canopy pins are very floppy. Have back and forth movement before ever applying any pressure. Overall, I believe next time I will spend the hour that it took to put this thing together at work and spend my money on a better frame. Good thing I picked up a rakon v2 in a trade. I don't like the Rakon as much as the microheli but side by side its an easy choice for me. If the screws would have tightened I would say its a pretty good frame other than the canopy pins but who wants to go through the trouble of taking all those screws out to change out the canopy pins just to put them back and the screws hold even less. I am still yet to put the spin motor in it. Kinda lost my motivation with the disappointment. Others may very well have plastic parts made to were they tighten correctly. Just thought I would get my experience down here because im sure there is going to be others with the same issue's. |
#19 |
well u just about put me off it new bee but i've just went and bought one of these, its only £23 so thought fek it, i want to see how this flies with something a little more solid.
i would have liked the new MH X frame but it'll probably be a wee while until i can get my hands one anyways so this will do till then main thing i like is the metal motor mount. |
#20 |
Yea I thought maybe I wouldn't use it but there crash kit is pretty cheap and has most of those plastic pieces so I guess the spin in going in there today. Order the crash kit also cause im sure i'll need it.
