Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 03-13-2012, 03:27 AM   #1
rotor head33
Default What about these rotortechs
So I have 609mm rototechs on the bird now. Never flown rototechs before and really wanna sell them and put some radix 625v2s. Do yall think that I could make a good chunk off the blades? Blades are flawless or do they fly ok. I want super fast cyclic control (running flybarred)
velocity 50- Total G
rotor head33 is offline        Reply With Quote
Old 03-14-2012, 05:37 AM   #2
Dumbthumb75
What do the Rotortech's weigh compared to Radix? As the Rotortech's are shorter, I would expect them to give faster cyclics than the longer Radix, but weight also plays a difference.
In essence:
Shorter, lighter blades = faster cyclics, less stability in FFF, less energy in autorotation.
Longer, heavier blades = slower cyclics, more stability in FFF, more energy in autorotation.
minicopter Diabolo, Henseleit TDR, MA Spectra-G, Raptor 50T
Futaba 2.4 GHz
Dumbthumb75 is offline        Reply With Quote
Old 03-14-2012, 09:24 AM   #3
rotor head33
Never really looked at the specs and I agree and understand your reasoning. Apparantly they seem to be a pretty popular blade but are definitely ugly IMO. I'll compare and contrast specs I guess
Old 03-14-2012, 09:57 AM   #4
fastflyer20
They have the lightest, quickest 690 blades I could find and really like them. Try them before condemning them,especially if you like quick cyclic.
fastflyer20 is offline        Reply With Quote
Old 03-14-2012, 10:26 AM   #5
ngin
The Rotor Tech's have been my favorite blades for awhile now.
I have found after using many blades that weight is not the only criteria t determine performance. I think where the weight is placed - further inboard or outboard on the span and/or further forwarard or rearward on the chord) effects the performance more then a few grams of weight difference.
The airfoil and tip shap also have a great influence on that performance and the ones used on the RT's seem to work very well.
I think you should try them. You may find you really like them, just as I did.
ngin is offline        Reply With Quote
Old 03-14-2012, 11:06 AM   #6
rotor head33
Should I stick to 610s or go bigger? I'll try them out!!
Old 03-14-2012, 11:07 AM   #7
Dumbthumb75
An additional "spec comparing tip" after reading post #5 :
If it's marketed as a 3D blade, the chordwise CG is usually more forward, This also goes for narrow chord blades. Therefore, in general, a blade with comparable narrow chord is more agile than a wider chord.
Futaba 2.4 GHz
Old 03-14-2012, 11:09 AM   #8
rotor head33
I agree
