Old 03-19-2012, 11:34 AM   #1
flyinghigh450
Default How do I go back to V2.1 with the 3G?
I downloaded the file so what do I need to do next?Sorry,first time and not sure what to do ..
Team Align
flyinghigh450 is offline        Reply With Quote
Old 03-19-2012, 12:16 PM   #2
Stevendavis
You have to plug just the gyro into the USB and use the 3G V2.1 Update, not the 3G V2.1. Once the Gyro is updated, then just plug the 760 controler into the USB and update it. Once that is done, you can open the 3G V2.1 program and link up to it normally,, with both gyro and 760 controler plugged into the USB.
Blade MCP-X Brushless, Trex 600 ESP 6s 3GX and KDE head, Trex 600 LE , OS 55 Hyper Limited Edition! Trex 700 Nitro, OS 91HZ with Hatori pipe, 3G FBL. Futaba 14MZ controle!!
Stevendavis is online now        Reply With Quote
