Go Back   HeliFreak > R/C Electronics Support > CJY Total-G FBL System
CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support
Old 03-19-2012, 06:14 PM   #1
foolforspeed
Default Align DS650
I have a ds 650 for the tail. It has a pulse rate of what looks like a backwards ys 1520. Is that the same as ms1520? There are only 3 servos listed on the choices for tail: fut9256, fut bls251 (which I can't find a pulse rate spec for), a JR 8900g (pulse rate of 1520ms), and then a standard digital servo. Which one do I select. Help!!!!!!!!!!
:wow2 :
foolforspeed is offline        Reply With Quote
Old 03-19-2012, 06:15 PM   #2
heliddd
1520uS
heliddd is offline        Reply With Quote
Old 03-19-2012, 06:47 PM   #3
foolforspeed
So is us the same as ms?
Old 03-19-2012, 08:14 PM   #4
vboy55
Use jr8900
Tommy
vboy55 is offline        Reply With Quote
Old 03-20-2012, 08:50 PM   #5
foolforspeed
Thanks vboy55 I confirmed that with Brian @ CYB. I'm sure somebody has put this unit on a 700N before. I've got a lot of questions. I'm confused with the gear ratio setting. The rpm seems be be locked in I guess depending on another setting?
Old 03-20-2012, 09:33 PM   #6
vboy55
It's really simple once you get the hang of it. If you need some help I can PM you my number and we can go over it tomorrow after I get off work.
Tommy Wagner
