Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 01-14-2013, 04:47 PM   #201
350Z_Al
Excellent read guys, good job with the research and testing!
Just to confirm, I am OK with the setup below, using an RX pack and AR7200BX?
Savox 2271 & 2272 into the AR7200BX. 2S LiPo 1800mAh 65C directly into the AR7200BX through two open ports.
It sounds like using the RX pack is safe, I could add a DC-UP there if necessary. I guess my concern is with the power bus through the AR7200BX, is it adequate to support the servos, or should I add something like the Skookum power bus?
Align 450 PRO DFC 4S KDE 450XF // Blade 450X 450MX, 3GX, Savox // Align 450 Sport V2 Airwolf
Align 600EFL PRO, DFC, 3GX, KDE
Align CHP DL 800, XERA 4530LE, ICE160HV, AR7200BX, SB-2271MG, SB-2272SG, KDE, Lynx, 115s
Thunder Power 65C LiPo & JR 12X
350Z_Al is offline        Reply With Quote
Old 01-14-2013, 05:13 PM   #202
akschu
Good to go. The issue isn't passing the current through the wires, the issue is that the regulator can't handle the amp spikes, the DC-UP fixes that.
In your case, you are using a real battery, so no regulator or DC-UP is required.
schu
akschu is offline        Reply With Quote
Old 02-21-2014, 08:06 AM   #203
msallua
Hi, The Align BL 700H are Savox sb-2271sg re-branded,
Frecuency of the servo?
200hz as seen in Beastx website http://www.beastx.com/service_servoliste.php
or
250-333hz as seen in the Savox website
http://www.savoxusa.com/Savox_SB2271...avsb2271sg.htm
I have a problem with this servos with the IKON
http://www.helifreak.com/showthread.php?t=604176
Thanks in advance
Align 700N DFC, 105HZ-R // Sab Goblin 700Comp // Sab Goblin 500 // Align 700E DFC HV.// 2x Align 450L Dominator .// Futaba 14Sgh - RealFlight 7.5 - Powered by Pulse - IKON's
msallua is online now        Reply With Quote
Old 02-21-2014, 04:33 PM   #204
prototype3a
Has anyone tested with a Jeti Mezon 130?
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL
prototype3a is offline        Reply With Quote
Old 02-23-2014, 09:01 AM   #205
Swooper6
I had a similar problem with Savox 2274 at 350oz torque. At fast inputs it would studder as they were drawing too much. I put a multimeter through a tm1000 on my setup just to check and the servos would drop to 4.8-5.0v. To fix it I switched to the SG Reactor HVX which regulates a 3s down and with it I have not had an issue. The 3s really leaves a lot of possible backup power to your servos plus 25amps. It is a little expensive though:
https://www.greathobbies.com/product...rod_id=SGP5690
Team Empire/GAUI North America
Great Hobbies
Scott Gray Products
iKon Flybarless
Swooper6 is offline        Reply With Quote
Old 02-23-2014, 09:36 AM   #206
whippo
2s through a sk540 no issues
________________
Naked & Afraid
whippo is offline        Reply With Quote
Old 05-04-2014, 03:08 PM   #207
SergeyBSB
Default Servos for X7
Help.
I can not select for servo Gaui X7.
Savox SB-2271SG (Swashplate) + SB-2272MG (Tail Rotor) ? --- Now cheap and selling.
New Savox - 2284SG + Savox - 2283MG ? ---- New-w-w!
Futaba BLS275SV + BLS276SV ? --- Big price but Futaba!
Servo Savox declared as a fast and strong. But is it really?
Perhaps someone used them and knows the difference?
Who knows the + and - these servos.
Sorry for my english,
Sergey.
SergeyBSB is online now        Reply With Quote
Old 05-04-2014, 07:21 PM   #208
borntofly
I have used 2271sg's for around a year on a BEC (gryphon) on my E720 without any issues.
Have not bench tested like the video but no problems in flight.
Ran them on 8.4v.
Sent from my GT-I9305 using Tapatalk
borntofly is offline        Reply With Quote
Old 05-04-2014, 11:30 PM   #209
Matt Nasca
I run the 2271s and 2272s and have not had any issues with them at all. I run mostly a 2S lipo but have a set on the BEC in a Talon 90 and they've been just fine. Strong, fast and tough.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote
Old 05-14-2014, 03:27 PM   #210
Swooper6
Default Re: Caution: Savox SB-2271SG Cyclic Servo Bench Test Results
I use the 2274's on cyclic on my x7 and they are amazing. I have Scott grays hvx for a reg though so it's 3s and 25A. Probably not the best comparison since most run 2s but I thought I'd post anyway
Great Hobbies
Scott Gray Products
iKon Flybarless
Old 08-08-2015, 06:50 PM   #211
prokyon
Does anyone know if this is a production issue with the servos or the actual design? If this is a production issue then has it been fixed?
Synergy E7se (Scorpion) | Synergy E5 (KDE) | Gaui X3 (XNova)
Mikado VBar | MKS Servos | HobbyWing V4 | Rail Blades | Pulse
Spektrum DX8 | Heli-X6 | Lynx Team Pilot
prokyon is offline        Reply With Quote
Old 08-08-2015, 07:18 PM   #212
prokyon
Also, can WR BEC handle these at 8.2V?
http://www.western-robotics.com/wrl-hbecsp
Old 08-08-2015, 08:03 PM   #213
prototype3a
I would expect that unit to do fine from my experiences with these servos. I've run them hard on the Jeti Mezon 130hv's internal BEC without issue. I did back it off from 8v to just ~7.5v after a while though for peace of mind.
Old 08-25-2016, 11:56 PM   #214
FlatCrank
Default Savox SB-2271SG let smoke out
I've got a set of Savox SB-2271SG cyclic servos on my Goblin 700 Gasser. Hooked up RX pack today and the iKon initialized all servos just fine. Started the engine and one of the servo arms shot straight up vertical then the back/bottom plastic servo plate quickly developed a smoking hole through molten plastic about the size of a pen hole. Servo arm is locked straight up now. .
Will try to post pictures later. Don't know/understand what caused it since the iKon and servos are powered through RX pack and all else was just fine and all other servos continue to operate normally. Believe I will replace with MKS HBL380's. I've had good luck with all my other MKS'.
Field Rep for Lynx Innovations and MKS Servos
Citizen 821
Oxy3 285, Goblin 500 x 2, Goblin 570 Stretch 12S, Goblin 700 Gasser
FlatCrank is offline        Reply With Quote
Old 08-26-2016, 06:34 AM   #215
prototype3a
Sounds like either manufacturing defect in the servo or just dumb bad luck to me.
Old 08-29-2016, 03:00 PM   #216
akamullen
I put my 2271SG servos in my E-revo after they caused two separate crashes on my X7 years ago, I thought I had them working, but after a bunch of good flights, they decided to brown out my system, Flew with BEC, then RX pack / capacitors. Darn servos have too high of a amp spike when in use.. Maybe some guys can get them to work(or have gotten lucky), but I had nothing but trouble with those savox servos. I run BK 7002's on cyclic and 7006 on tail now and no issues at all with Castle BEC pro (bec powered by one of the 6S flight packs) set to 7.5v.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 380/500-x2/630/770 * Swinging SWITCH/RJX/RAIL & SAB Blades * Microbeast/IKON * Castle ESC's on all * DX18 *
akamullen is offline        Reply With Quote
