Old 03-23-2012, 10:31 PM   #1
Ermac
Default Pick my blades
Trex SeV2 FBL
IDK which to go with
Edge
Maverick
Radix
I like shiny expensive stuff, that will help in 3d.
Ermac is offline        Reply With Quote
Old 03-23-2012, 10:53 PM   #2
Wildcards
FB or FBL ?? whats your flying style ??? There is not the end all be all blade, it depends on what your looking for.
USMC - EXPEDITIONARY AIRFIELDS - MCAS MIRAMAR
Align Trex 500 Scorpion 3226-1400 powered missile
Wildcards is offline        Reply With Quote
Old 03-23-2012, 11:17 PM   #3
MXRACERX43
My bias opinion says Mavrikk!
Team Miniature Aircraft
Team GensAce ~ Mavrikk
MXRACERX43 is offline        Reply With Quote
Old 03-23-2012, 11:28 PM   #4
DesJardins
All are great, I went with EDGE. The mostly black blades I just don't care for.
Blade 450X & Blade mCPX BL
Spektrum AR7200BX
ProgressiveRC's "The Neutrino Ticket"
DesJardins is offline        Reply With Quote
Old 03-24-2012, 03:29 AM   #5
lankey
FB choice would be Thunder Power 325's.
450 PRO, 500 ESP
Due to economic circumstances, the light at the end of the tunnel has been turned off until further notice.
lankey is offline        Reply With Quote
Old 03-24-2012, 10:56 AM   #6
Wildcards
My vote is FB = Align CF
FBL = Edge
Old 03-24-2012, 09:38 PM   #7
Blade120
I went with edge also on my 450, but i have some radix on my 500 and they're really good , i thought visibility would be bad on the Radix cause they're mostly black but they're pretty visible.
Both tracked perfectly and balanced right out of the box. Have used aligns also and they're good too specially since they're quite a bit less money but the finish was'nt as nice as the edge or radix.
Trex 500 ESP(DFC) Ikon, Radix] [Goblin 700 CompBK, 4525, Ikon, Helix 695 ] [Rave ENV Nitro O.S 105-R,Ikon,Cyclone] Rave ENV Electric]Scorpion 4525,Ikon, Outrage, SAB [Goblin 500] Ikon Rails 516 ]Blade 180 CFX]Goblin 570 12S Xnova
Blade120 is offline        Reply With Quote
Old 03-25-2012, 10:46 AM   #9
DesJardins
1 vs. 2 is FBL to FB
3 with the VST looks like a new design of the FBL #1
3 vs. 4 is FB to FBL
5 is FBL
All are Carbon Fiber high quality blades.
So rule out the FB vs. FBL depending on what you want
Here's another picture of persuasion
Spektrum AR7200BX
Old 03-25-2012, 12:11 PM   #10
Ermac
The edge blades are very pretty hehe. Has the best looks out of all the blades, Man I wish I can find YELLOW blades I love yellow.
I wonder what is the difference with vst other than it's the "new" version.
I really want Mavericks but I dont find anyone selling in Canada....
Where do u guys buy your maverick blades?
I am FBL, would it screw things up if I used FB blades? I'm curious about the cheap hobbyking ones and idk if they have "FBL Blades".
Old 03-25-2012, 12:26 PM   #11
DesJardins
You can toss any blades you want on, granted depending on your FBL unit settings FB blades will give different reactions.
If your FBL, then I personally haven't seen a benefit of putting anything less than FBL blades. Just remember what "cheap" typically stands for.
Don't let a good price point be the failure of a high headspeed pricy Helicopter.
Just my opinion of course & you'll get many along the way
Spektrum AR7200BX
Old 03-25-2012, 12:31 PM   #12
Ermac
hmm well what's the cheapest fbl blades u tried that have not yielded any negative results thus far?
Old 03-25-2012, 12:45 PM   #13
DesJardins
Cheapest FBL blades I have put on were the Align 3G's
The difference in stability/predictable control (& I'm no advanced pilot) wasn't a tough decision for me to drop the lower end blades and just run with the EDGE blades as they have been great on all my helicopters
Spektrum AR7200BX
