| Other Makes and Models Helicopters Other makes and model Helicopters |
Here is my new HK600GT after my first 2 minute hover. Included in the build:
Turnigy Typhoon 600H brushless motor w/13t pinion Turnigy K-Force 150A brushless ESC BMS 621MG servos (3) BMS 661MG tail servo HK401B HH gyro RotorTech 610mm night blades LED navigation light kit 5000maH 6S 30C lipo's Castle 10A BEC Align upgrades include main gear drive, tail gear drive, and canopy. She flew steady in its first hover, no tail wag, just got to get the swash level. Overall, I'm in awe of the looks!!! ![]() |
That is a sharp looking Heli! Im building a HK450. would i be wise to jump to a 600. Nevr flown a big one yet in real life. Only 120's and under. Did u do all the paint scheme work! Any suggestions? Thanks
I started out with a 400, then upgraded to 450, then 500, and now 600. If you're pretty good at flying why not go for the 600? The bigger they are, the easier they are to fly. Plus, the HK600GT is CHEAP! I purchased some red decals from HeliDirect and "prettied up" the helo. The canopy is the icing on the cake. I'm looking into fuselages, but for now, I like the look of this. I'm not into 3D yet, just sport flying.
Towerpro mg946r dimensions 40x19x43mm?
If it is a standard size servo, it should fit...
#6 |
Would you mind sharing what your total build cost was? I have often wondered if you save anything by building a clone.
#7 |
My build cost me around 1000 euros.
Sent from my GT-S5830 using Tapatalk 2 Beta-5 |
#8 |
I didn't save very much. With the additional "custom" items (lighted tail and rotor blades, canopy, etc.) I probably saved approx. $300.00 U.S. dollars. Plus, I got a 150A ESC instead of an 80A ESC with the Align TREX 600 kit. I look back and see the TREX 600 kit at $900.00 and I think twice about the HK600GT. But overall, I am completely satisfied with the buy. Plus, I don't think you can run a 6 channel rx and tx on the TREX 600, which I can on the HK600GT.
#9 |
Wow !
I just love this helicopter. Love the orange - black combination !!!! |
#10 |
Having built both the align 600 and hk 600 from base kits i found that the hk is about 30% cheaper overall using the same components from hk if you go the all inclusive rout from align you initaly save but if you upgrade electronics/ servos etc better to start with the hk especially if you ultimatly want to go scale
#11 | |
Regarding your statement that I quoted above - for my rookie mind - would you please clarify this? I thought I understood channels, etc, but I am unclear on why there would be a difference between very similar helis. Thx
Fusion 50, Blade 450 3D/FBL; mCPX BL, DX8 |
