Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 04-22-2012, 08:35 AM   #1
Swoop
Default 3GX manual
Where can I find the 3GX manual for download? thanks
Swoop is offline        Reply With Quote
Old 04-22-2012, 08:42 AM   #2
TBur
http://image.helipal.com/helipal-align-3gx-manual.pdf
Try this
7HV NEO 700XF
Goblin 630 NEO 600XF
Agile 5.5 NEO
Vcontrol
TBur is offline        Reply With Quote
Old 04-22-2012, 09:17 PM   #3
Swoop
Awesome thankyou.
Old 08-18-2012, 11:14 AM   #4
Tulo
Why does that manual start on page 20? Are there pages missing?
Tulo is offline        Reply With Quote
Old 08-18-2012, 11:22 AM   #5
draeh
The manual is embedded in the build instructions for the various Align kits. This appears to come out of the 450 manual. At least its identical to my 450 manual that starts on page 20.
draeh is offline        Reply With Quote
Old 08-18-2012, 01:21 PM   #6
Tulo
That's kinda what I figured thanks!
Old 08-18-2012, 09:33 PM   #7
bad007
The software is the manual. Just leave the servo horns off until your in setup and install them as close to level as poss at mid stick.
Align 450Pro 3GX Edge KDBB, Align 500 DFC 3GX, Align 500L MicroBeast Plus HobbyWing Platinum Pro V4 Plus Switch Blades, KST HV Servos, Align 550 DFC MicroBeast Plus, Velocity 50 Vbar 5.3 Pro, OS55 HZ-R, Radix V2 KDBB Castle,
bad007 is online now        Reply With Quote
Old 08-18-2012, 10:43 PM   #8
Tulo
I haven't been able to find the bind procedure, can anyone help me out??
Old 08-19-2012, 09:24 AM   #9
bad007
The bind procedure is in the software/manual. If your using sats you bind the 3GX, if your using a separate RX you bind that instead of the 3GX and follow the instructions for the TX / RX for binding and wirring for channel assignments
Old 08-19-2012, 02:59 PM   #10
Tulo
I have 2 sats, so would I just:
1. Insert bind plug into 3gx
2. Plug in flight battery
3. Push bind button my spektrum tx module
4. Power on Futaba 10C
5. Wait for some sort of jingle or series of flashing lights then release bind button
Does that sound right?
Old 08-19-2012, 03:17 PM   #11
bad007
Yep, the sats will blink fast whan you power the 3GX, they'll go out for a few seconds while binding and come back on solid. Then you remove the bind plug and power down. 3GX first and then the TX.
Preview the software and read everything and get familiarized with it. It is the instructions.
Old 08-19-2012, 03:28 PM   #12
Tulo
What software?? Are you sure you don't remove the bind plug after powering down?
Old 08-19-2012, 03:53 PM   #13
bad007
What software, this software. It's a must and to be used with the dongle via usb port on the PC. And yes you remove the bind plug while still powered, it sets fail safes, throttle etc.
Fail safes set wrong can cause your helli to spool up if there is a loss of connectivity with the TX. Been there,,, done that!
http://www.align.com.tw/alignhtml/3g...gx_update.html
Old 08-19-2012, 04:07 PM   #14
Tulo
Cool, I appreciate the help! Where can I get the 'dongle'? Does all that stuff pictured in the link come in the kit when you get it new, or is it an aftermarket option?
Old 08-19-2012, 04:12 PM   #15
bad007
When buying new everything comes that you need. It's just better to downoad the current software instead of using the disc that comes with it.
Old 08-19-2012, 04:14 PM   #16
Tulo
I mean like if you get a 550e super combo new, it comes with the connection wires?
Old 08-19-2012, 04:20 PM   #17
bad007
Just E is a flybarred helli, has to be a 550EFL. FL meaning flybarless and then you get all the cabes you need including the dongle, usb cable and patch cables if you run a separate RX. The original 3G didn't come with the dongle and cables and had to be pruchased separatley
Old 02-03-2013, 02:10 PM   #18
Kiwi-heli-nut
Thanks for this! saved me a lot of hunting!
Westy's You Tube How To Guides -
==> http://www.youtube.com/user/rent2ownnz/videos <==
Gravity has a Great sense of Reality when your Wallet is concerned.
Kiwi-heli-nut is offline        Reply With Quote
Old 02-15-2014, 06:49 PM   #19
justwannahavefun
Default Loss of radio....
Saw your quote. Had to respond. About spooling up when you're not expecting it. Yikes. Turned off radio. Don't remember why. P.O.S. Blade 450 3D starts spooling up and at a good clip as well. Luckily the pitch apparently had fail safed at a negative. Unfortunately in the rush to stop my $300.00 heli from being hurt I decided risking my body was a good idea.
So I reach under the spinning blades to pull the power plug from the battery. Of course along with all the bad judgement going on I also misjudged the distance from the blades to my forearm. C L I P P E D.
Lots of blood and a nice chunk of skin removed but no E.R. visit. Just a very damaged ego along with the forearm.
I still didn't set my first proper failsafe until recently. I learn very slowly.
I still think a switch to in between the motor and power cables would be a good idea. I've seen one or two folks do it. It's a royal pain unplugging those banana cables from the ESC to the Motor.
Anyone got some good advice on that one?
justwannahavefun is online now        Reply With Quote
Old 02-16-2014, 03:06 AM   #20
Boinker
Hey there tulo. If im not mistaken I believe Futaba does not make satellites for there receivers or one that is compatible with the 3gx. Spektrum does make satellites but I am pretty sure they are not in any way compatible.
Please double check this. The good news is if its a Futaba S-bus receiver then it is capable of using s-bus and one wire to control the lot.
Boinker is online now        Reply With Quote
