| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
#41 |
I ended up at the LHS yesterday and bought an AR7200BX because the fastest frequency on the ZYX was 400Hz but the DS95i tail servo operates at 560Hz which the BeastX will handle. I mounted it on the bottom tray, and my CG is perfect. The DS95/95I servos are noticeably faster than the Hitec 5065/5084 and that's just on the bench. I will take her for a maiden this morning. See photos for wiring.
William Alees Rush 700-Kosmik 160A + KDE 700XF-495 Synergy N5C & E5-600 Protos 500 |
#42 | |
Have you used a sigle screw only (for each side) or two? The ball is at 15mm from the center?... Ciao from Italy Rino My Mini is standard model: 3S, stock motor, pinion, blade and it will be not changed... |
#43 |
Beautiful wiring job!
-Chris |
#44 |
TY sir. Took it for a maiden in the parking lot here at work and it flies equally as beautiful!! Can't wait until this evening so I can really let it stretch its wings.
Today, I've realized that I am running out of upgrades for my P450 ![]() CNC servo blocks and lower bearing block cnc pulleys Stretch kit 6s setup Ar7200bx super bright Fusuno canopy and tail fin. DS95/95i wire braid kit I think it's as pimped out as you can get a MiniP. Am I missing anything???
#45 |
Does it have the low head block?
-Chris |
#46 |
#47 | |
Beautiful job on the wiring!
Tom To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB Goblin 700 HC3-SX, Quantum 4530-500 Goblin Edition, YGE 160HV-K, WR Super BEC, MKS HBL 950 / HBL980 MSH Prôtos Mini FBL Stretch 4S vBar 5.3Pro, MSH 2010kV, YGE-60A, MKS DS95 / DS95i |
#48 | |
#49 |
What did I do today? Crashed again on my first pack. It's my second crash in a total of about 10 flights. Lost orientation and it was slightly windy out. List of broken items.
Both cf frame plates Bottom bearing bracket Bottom frame Main gear FG Blades Blade grip rod Bent hollow main shaft Tail pitch arms Tail spindle Tail fin I think I need to spend more time in simulator, and tighten up my sticks on the dx7s to match feel of the RealFlight controller. And just take things slower at the field. Might dial down my D/R and fiddle with expo, or just turn off tx mode for a while. It's embarrassing and frustrating, but I'm just a beginner, so I guess I kind of expected this to happen. At least I can install my aluminum servo mounts and bottom bracket now.
Mini Protos, 6S, Mini V-Bar, YGE 60, 3000rpm, 350mm 550e v2, 6S, Fullsize V-Bar Pro 5.3, CC ICE 100, CC BEC Pro, 2200rpm, 550mm Logo 550sx, 6S, Ikon, CC EDGE 100, CC BEC Pro, 2200rpm, 550mm |
#50 | |
That's what I am doing right now, they hit the ground, bounce and get straight back into the air(most of the time). It's a like a real would sim, I get board at the sim too fast, I never get board with a brushless MCPx in the air with 7000+rpm HS |
#51 | |
Mini Prôtos AR7200BX Prôtos stretch AR7200BX Savöx 1250/1290MG SAB 470mm ALeeS Rush 750 YGE 120HV/4035-530 AR7200BX Savöx 1258/1290MG Rail 696/116 mCPx stretch uHeli head DX18 AMA# 448427 |
#52 |
It was close. Might have missed it by a few ms. Concrete didn't help any. I'll stick to grass fields in the future. mcpx could have been purchased for the cost of these two crashes. I will consider that. I'm pretty good with my msrx, but it doesn't translate well to cp birds.
#53 | |
#54 | |
Coax teaches you nothing MSRx made me a quicker on the sticks, its a slippery little sucker MCPx felt like I started learning all over again MCPx BL gave me the power to try most stunts the big birds do Mini P I'm hoping will give me the real deal |
#55 | |
Lynx Heli Team Pilot Prôtos CF, 130X and many others. CarbonCore H6 950mm Wookong-M All on DX18! |
#56 |
#57 |
#58 |
Pulled the Mini out to fix up the broken servo gear in the DS410 servo and while I had it apart put the Metal gears into all of the servos. I will check the beastX configuration tomorrow and take it to the indoor meeting tomorrow night for its first flight in a couple of months.
I think I now have too many helis if I can leave one broken for a couple of months and still have plenty of heli's to fly. //Dennis.
Mini Protos FBL Stretch - 4s MSH Brain : Protos FBL Stretch - SK-720 : Protos FBL Stretch Night flyer SK-720 SAB Goblin 500 Ikon : Logo 600 FBL V-bar, 10s : SAB Goblin 700 Vbar, HK5020, Hawk 120A |
#59 |
Put 5 packs through her. She's as good as new. Tomorrow I'm shooting for at least ten flights.
:Sent from my Tapatalk using iPhone.
#60 |
Six flights on mine yesterday, first time in a while where the wind was less than 20mph!
The frustrating thing is before I stretched it the tail was PERFECT. Never had it blow out. After the stretch it just hasn't been right. For example, a long tail slide followed by a hard reversal into a vertical backward climb will blow the tail out every time. I've gone through the setup multiple times, and can't find anything wrong. In theory the stretch should have made the tail better, but in my case... not so much. ![]() A club-mate has one set up similar to mine, and he has no such issues. The only two differences are he's running Vbar, and he's got a DS95i tail servo. Gain can't go any higher without wagging, so I'm beginning to think my JR 3500G tail servo just isn't up to the task.
-Chris |
