| MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
#501 |
Well, can't comment on 3D performance of HK360's but they don't feel a lot different just bobbing around. They do seem to require a bit more collective to leap off the ground than the Lynx. They also seem to be less stiff than other blades I have. I have 5 sets of the HKs and I am flying the ones that needed the most tape to correct and I don;t notice any serious wobbles. Of course, Im not even sure if my mainshaft is straight right now either. Mini P with vbar seems to fly ok even when the mechs are all boffed up.
Mini Prôtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready |
#502 |
I installed some new tail grip bearings and new tail blades, oiled all bearings, silicone sprayed the belt. Checked the main grips bearings. Just a good old maintenance once over. I am planning on a full day of flying this weekend. Hopefully I can get in 12-15 batteries
I did notice some slop in the swash tho, not too bad I also installed my Radix blades, I am planning on bringing my Edge and HK-360's on Saturday.
T-Rex 500efl Mini Protos 6s Stretched 2x 130x (hp08 xp-12 10T, hp10s xp-12 10T) |
#503 |
Dumb thumbed mine today... Simple backwards inverted pass low on the deck and circuits just shorted in my head
![]() Considering I clicked throttle hold about a half second before it hit the ground rotor first, resulting damage is not bad - bent main, spindle (together with all the usual) and busted top main shaft bearing...plus blades and canopy, which was already on its way south for about 6 months anyway. ![]()
Tom To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Outrage Fusion 50 HC3-SX, A50-10L Turnado, CC ICE2 120HV, WR Super BEC, DH20-FTD / MKS HBL980 Prôtos Mini FBL Stretch 4S vBar 5.3Pro, MSH 2010kV, YGE-60A, MKS DS95 / DS95i |
#504 |
#505 | |
