Old 05-01-2012, 11:12 AM   #1
Zoot
Question Sudden Rudder Movement
Interesting but odd behavior.
When I'm flying, and input rudder, most of the time it is smooth, but now more frequently, the tail will suddenly move (jerk) to one side (left). It really catches me off guard.
The HH Gyro is set at 30 (true gain). Anything higher than that and I get tail wiggle.
This also occurs regardless of how much expo I add.
Any ideas?
Zoot is offline        Reply With Quote
Old 05-01-2012, 01:35 PM   #2
nightflyr
Any ideas?
Failing bearing.. possible binding....servo failure.....vibration..
nightflyr is online now        Reply With Quote
Old 05-03-2012, 07:04 PM   #3
justindewoody
Definitely sounds like binding in the tail. This has happened to me NUMEROUS times on my 450s, 500s, 600s, etc. check the tail grips and make sure they are not hard to turn on the tail rotor hub. This is usually the culprit.
Canomod Team Pilot | Gobline 380 | Goblin 700 Competition | Goblin 500 | Mostro 700 DFC | Gaui X7 | Gaui X5 | Trex 450L Dominator | Trex 250DFC | FlameWheel F450
justindewoody is offline        Reply With Quote
Old 05-03-2012, 08:26 PM   #4
Zoot
I noticed, the "tail rotor shaft assembly" gears looked fine, but when I turned them there was resistance. So I replaced those gears, plus the "front umbrella gear" and "front drive gear assembly", just to make sure. It now spins very smoothly!
I'm not sure what you mean by "tail grips". I have a habit of referencing the part names in the 600 manual. Can't keep track of all those names. : )
I'll test it out when my new set of blades, and landing gear arrive.
Thx much,
Zoot
Old 05-03-2012, 09:43 PM   #5
justindewoody
The tail grips are the things that the tail blades are bolted to. There are 2 of them and they are attached to a center hub. They have bearings in them at their base where they attach to the hub. I quite often have those bearings lock up, which means the tail grips do not easily spin left and right on the hub. They BIND. This will cause all kinds of terrible stuff, namely MAJOR tail wag.
Old 05-03-2012, 10:24 PM   #6
pril250
Some times even if the tail components feel smooth on the bench once the centrifugal forces come into play some items can lock up.
Blade400
pril250 is offline        Reply With Quote
Old 05-04-2012, 12:12 AM   #7
Zoot
Ok thx, I'll make sure to check!
Old 05-04-2012, 12:13 AM   #8
Zoot
Interesting. : )
Tags
movement, rudder, sudden, twitch
