Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 05-06-2012, 01:13 PM   #1
RCnut1980
Default Blade Size
What size blades are best for 3d on the x50b (redline .53) - 600's or 620's?
What is the performance difference between the two, and what are you guys running?
RCnut1980 is offline        Reply With Quote
Old 05-06-2012, 03:06 PM   #2
carlos
600's are easier on the motor, 620's are better for collective "pop" and autos.
I prefer 610's
If it won't hover, Don't bother !
carlos is offline        Reply With Quote
Old 05-06-2012, 08:03 PM   #3
KouDy
I am running stock 600mm now and have my eyes on 603mm Edge. As for 620mm sizes can they work? It looks to me that there would be interference to the tail rotor.
Performance wise bigger disk means bigger stability but also more strain to the engine as it's more mass to spin.
Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
Old 05-07-2012, 01:31 AM   #4
carlos
no interference when running 95mm tails
Old 05-07-2012, 02:05 AM   #5
KouDy
Cool thanks for the info! So i can use Edge 623mm without worries.
Old 05-07-2012, 02:27 AM   #6
RCnut1980
I like the new SAB red 620 blades, but what brands do you recommend for 610's?
Old 05-07-2012, 05:03 AM   #7
NitroAl
I find the 620s too floaty on the X50. So far I have tried Radix 600's, Edge 603's, GCT ultra pro extream 620's (Maveric pro wide chord) and the TT carbon blades that came with my two kits and my pick are the TT carbon blades and the Edge 603's.
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
Old 05-07-2012, 02:42 PM   #8
carlos
610's, Rotor Tech are the pick
Old 05-07-2012, 10:18 PM   #9
johnbs8
i fly compass 615mm blades. they fly great. i got them when they were $65 now they are up to $80. glad i got em when i did.
Titan X50B : YS56sr GP Pipe, Tracx600 FBL, AR7200BX, Ds610 X4, DS650, Pushglo and compass 615mm FBL
Titan X50T : Ys56sr SAB-55 Pipe, Tracx600 FBL, AR7200BX, DS8717 X3, BLS251, Pushglo Radix V2 625mm FBL
johnbs8 is offline        Reply With Quote
Old 05-08-2012, 05:34 AM   #10
RCnut1980
I'm in the UK and all stockists seem to be out of Rotortech blades. Could anyone suggest a good US stockist please?
Old 05-08-2012, 07:06 AM   #11
KouDy
Same for asia. Virtually noone has 600 class blades on stock. Mat Botos blades are not here at all. I will probably try Edge or something...
Old 09-12-2012, 05:46 PM   #12
Adam F
Can i use radix 625 on my x50T that i converted to flybarless?
Adam F is offline        Reply With Quote
Old 09-13-2012, 01:06 PM   #13
johnbs8
Adam, ypu can use 625's. I used them for a min. I didnt like them as they were too slow on cyclic. They fly more like an airplane. I use the edge 603 fbl and they are great blades. I tried a set of the edge 603 fb and they flew awsome too. Both my x50's are FBL.
Old 09-26-2012, 11:05 AM   #14
Adam F
Thanks for the advice
