Go Back   HeliFreak > R/C Electronics Support > Eagle Tree Systems
Eagle Tree Systems Onboard data loggers, telemetry, and OSD support
Old 05-09-2012, 09:50 AM   #1
janez
Default HELP!
hi!
I burned my Eagle Tree GPS V4 with power supply 12V.
Burnd out is IC with code U1.
Please, can you tell me, what it the full name of this IC, so i can replace it.
IT IS IC (5 LEGS) NEAR TO THE BROWN WIRE.
Can someone who has Eagle Tree GPS V4 view IC code.
Please someone send me the picture of the back side of the GPS V4.
Regards
janez is offline        Reply With Quote
Old 06-20-2012, 10:28 AM   #2
YoungBull
I know nothing about your system, however I just looked in google images for pics of your unit and there is page after page of what you might need. Back / Front / Side inside and out.. Alot of these images should take you to links that may have the same problem..
This link might also help.
http://www.eagletreesystems.com/Supp...timeter-v4.pdf
Hope it helps.
450 se, 450 v2, using Jr 2610.
550e 3GX , Dx7, 1 sat. RF6, Redback LiPo's.
600efl Pro, 3GX, bec, Castle HV80, 2 sats.
YoungBull is offline        Reply With Quote
Old 12-17-2012, 06:27 PM   #3
satgod
I hate to say this but your probably going to have to spend 53.00 and order a new one
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
