| Mikado Logo 800 Xxtreme Mikado Logo 800 Xxtreme Helicopters Discussion |
Hi,
I'm wiring up the Xxtreme with the included YGE and VBar in addition im using the WR Hercules Super BEC and a Futaba R6208SB (first time using BEC n SBus Receiver) Does anyone have a breakdown list or diagram of the correct channel connections between the SB Rx and the VBar unit. The part I'm stumped at is... I put the ESC wire into the Collective/ESC port on the VBar instead of into Ch3 of the Rx so then which Rx Ch do I connect to the VBar unit to relay Throttle signals to VBar... Also i seem to b running out of ports on the VBar unit so i thought to put one BEC output to the VBar unit and the other to the Rx....? Thanks |
Need a wire from the reciever sbus port to the AUX on the vbar.
all signals will go into the vbar , the vbar will process them , then send out to the esc thru the collective/esc port extra wires for the bec can go into any spare location left over. ( servo channel 4 on vbar , left over port on receiver , etc. ) if this is your first futaba installation the throttle needs to be reversed. Then of course calibrate the transmitter to the vbar software and such as normal. YGE esc in the XXtreme has a built in rpm sensor so that needs to plug into the vabr also , with the adapter in between Martin
Logo XXtreme 8917 / 256HV Logo XXtreme 700 8917 / 256HV Logo 600 : bls451/ 9256 , V-bar , QUK tail , Edge 623FBL , 4035-500 for sale Logo 600se : bls 451/251, QUK tail , Edge 693/105 , Scorp 5020-450 for sale |
Thanks Martin,
Rgds |
#4 | |
Cheers Mac
Spektrum DX8 : Logo XXtreme 800 : TRex 700N DFC : TRex 600N DFC : Goblin 500 : Blade Nano CPX : |
I'd assume it would be the single line as plugged into the vbar.
The adapter takes 2 lines to the far side ( negitive or black = ground reference ) and one more line that goes to the signal portion of the connection ( servo orange/white wire ) My assumptions as the 800 is my first vbar'd govenor. I'm a jive spoiled guy that doesn't have $800 for a kosmic Martin Please confirm with someone with some experince before hooking up
#6 | ||
upgrade IMHO Cheers
#7 |
The way mine is, . If you we're sitting in the Heli looking out the windshield, the rpm lead is the lead on the left.
Think there is a diagram n the manual showing this. |
#8 | |
Are you using the TM1000? If so do you use the main pack voltage sensor on all 14s or just monitor 7s? I know it can handle 60 volts so thought I'd just do 7s incase of spikes but if yours is working on all 14 I'll do the same. TIA
#9 |
I do use a tm1000
I mounted the vbar sensor the same way as in the manual. I trimmed the lead as it was to long and crimped on a new connector I connected both the tm1000 port and the vbar to the sensor adapter coming for the ESC. Works fine I monitor the 14s pack voltage. I am not sure why you think there would be voltage spikes coming from 14S pack. Its voltage is what ever it is, and dropping all the time. cant see how it would go above the sum of its cells voltage. Am I missing something here? Also the tm1000 can handle 2s power for ex pack voltage, I ise that iPhone gizmo so I get spoken telemetry values and logging. Works great. I found an old iPhone 3G, use it only for Rc, carry it with the transmitter, I fly with that in my coat pocket, spoken telemetry is the way to go IMO |
#10 | |
