| Beam Avantgarde 600 Beam Avantgarde 600 Support Forum |
I have had my Beam Avantgarde for a couple of months now, and i am very pleased with it, and extremely happy that i got one!
It all began because i was looking for a 50 size heli to be my new 3d training machine and a girl flying in our flying field bought the Avantgarde because she thought it was pretty I saw her hoover it and decided i wanted one too.. It flys so different from all the other helis i have had, it is very light in the air and so easy to do tricks with, it just feels like you have extra time to think, it doesn't just fall.. I am especially happy with it because if you crash it, it is super easy to repair, it takes me shorter time to repair the Beam than it takes for me to repair the Trex 450pro and that is fast:-) I noticed how easy it is already when i build it from scratch, the manual is only 8 pages and in 1:1 i got surprised when i finished mine, huh already done:eek: When i crash it, it rarely bends the feathering shaft and also not often the main shaft, it always takes the red blade holder grips, i think they have been made soft on purpose, because it really helps not bending those shafts! On the frame it is only those extra "crash parts" that brakes, it is those that hold the canopy, they are on the frame but not part of the frame, so the frame is very protected against crash and the canopy is made with good quality and it is very thick, so the batteries and frames are also protected by the thick canopy. The frame is not super thick, but has extra carbon in each corner, so the frame is strong, but the heli is still super light weight, i think it is the same weight as the logo 600 with plastic frame.. So far i haven't had any problems, i changed the belt to the upgrade belt so it doesn't make sounds from belt touching boom nothing else.. The first time i flew it i couldn't stop smiling it took me only 1 maiden flight and 1 get to know flight, and then i felt like i never flew anything else I love my Beam Avantgarde Here i crash it HARD! it took me 60 minutes and i was airborne again A friend of mine made this video at the Pitchbrothers Smackdown this year.. I never owned a Beam e4 but after trying the Avantgarde i think i want one ![]() With kind regards Benjamin |
Very nice flight
Personally, i preferred the second one
Warp 360 , Tarot 480 T500Fbl AP MCPX bl PZ StrykerQ DX8 |
How much does it weigh with batteries? Is it hard to find parts in USA?
. Futaba 14SG, Compass 6HV, Beastx, TP 2 2700 65C, POWER LAB 6 |
#6 |
so far as i can see amainhobby is the us distributor and i see experiencerc sells them too... as for weight not sure ,mine have brushless servos and a 700mx motor ,so mine is a bit heavier. but still really light compared to some..
#7 |
let me point out,.yes the kit is 600$ but so far i feel well worth it and the parts are very low cost. plus belt drive makes it very low cost...
#8 |
My Avantgarde weighs 7 lbs. exactly - with a Hyperion 5 Ah 6s 35C battery.
(Flight time 5 minutes.) A 12s setup would be just slightly heavier. Cheers Erik
Beam Avantgarde600 FutR6203SB, Hyperion 4025-1100, ICE100, black V-Bar, Graupner 806BBMG Fut9254 T-Rex500esp - Fut6203SB, Scorpion 3026-1600, ICE75, 3 x DS510, blue VBar, BLS257 T-Rex600N, Align 50 Hyper, S9252, S9254, CSM SL720 |
#9 |
Who has this 600 and a 700 size and what would be the difference? Is there that big of difference between a 600 and 700? Someone at the field suggested me sell my 500 and go larger. He was flying a 700.
#10 |
you know whats a really kick ass heli and its inbetween the 600 and 700? A century e640 fbl. i have one,smooth and built well. all the bearings are double the size of my beam. uses 640mm blades,
#11 |
I was looking for a belt driven bird. That heil looks really cool. Are parts easy to get? I would have to stock up on tail gears ha!
#12 |
the gears are pretty strong,, there is metal helical tt gears coming out for it.
#13 |
Speaking of gears, I am finishing my build tonight and wanna put some numbers in my governor.
Does the black main gear have 120 teeth or 150 ? I found both numbers online. I am using the 12er pinion on a 4025 on 6S Looking so much forward to tomorrow Maiden flight :-D |
#14 |
Using MrMel i am getting solid 2200 using a 120 gear , 12 pinion and 1100 kv.
So I guess it's not 150 which would result in 1650... Ah screw it, I'll count em myself |
#15 |
And it's airborne :-D
Maiden went well, feels very very light. Now test flights can start , it's just really windy today . Built went just fine , so did the setup |
#16 |
Aaaand its down ..
Question guys , how big is your distance of the tail servo horn ? I found out the swash servos have 17 mm. On the tail I have only 13 using a DS 620 Servo . Is that too little ? the metal rod looks straight though . |
