Old 06-17-2012, 08:29 PM   #21
memosteve
HeliDirect.com Team Pilot/Rep
Align T-Rex 700LE FBL, OS 91HZ-R, Hatori SB-20, Beast X
Align T-Rex 600LE FBL, OS 55HZ, Beast X
Outrage Velocity 50N2 FBL, OS 55HZ, Beast X
memosteve is offline        Reply With Quote
Old 06-22-2012, 06:36 PM   #22
Black_heart
I was also one of the lucky ones to get to test this to from RDG.
I put it in My Hausler 450 AirWolf Fuselage I stell need to do a little more tweeking But
http://youtu.be/nj2uOL0H-eQ
Black_heart is offline        Reply With Quote
Old 06-23-2012, 12:54 AM   #23
Razors
Perhaps i need one of these on a Tarot 450
Razors is offline        Reply With Quote
Old 06-25-2012, 06:03 PM   #24
satgod
I have some 600efls I can mount one on and do videos all day
would love to test one
I think I would like to be a U.S. dealer for them
I wouldnt pay 150-200 for a beast-x but for a good clone of one I would pay 60.00
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530
450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon
TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF
X-8 Wing , D/L UHF Full fpv package
satgod is offline        Reply With Quote
Old 06-30-2012, 02:51 PM   #25
Spork01
The Hobbymate HB800 FBL gyro is now in stock at hobbycool
http://www.hobbycool.com/hobbymate-f...ers-p-715.html
Trex 450 Pro V2 FB spartan quark
trex 250 beastx
Fusion 50 beastX
Spork01 is online now        Reply With Quote
Old 06-30-2012, 09:02 PM   #26
Spork01
a video from one of the test pilots
trex 250 beastx
Fusion 50 beastX
Old 07-03-2012, 12:47 PM   #27
Airman0386
So this HB800, or the tarot XYZ, or the copterx 3X1000?
mCP X - 130X - 250 FBL - 250 FBL #2 - 450 - X5 - DX6i
Airman0386 is offline        Reply With Quote
Old 07-03-2012, 05:31 PM   #28
khogan
lol even cloned the beastx description
http://www.beastx.com/products.html
Name:	lol clone.jpg
khogan is offline        Reply With Quote
Old 07-03-2012, 07:06 PM   #29
mayday1
This hobbymate FBL seems to be a clone of beastx v1, which seems outrageous. I wonder if
it is sanctioned by microbeastx itself to create a lower cost alternative to compete with the new
crop of cheap FBL controllers like tarot, copterX, ...etc. If it is an outright stealing of IP, I would
expect you can get a HB800 and update it to beastX v2.0 firmware and beyond. The fact that
you'll turn it to a brick if you try to update indicates that they've actively changed something to
make it different. Without source code of the original beastx it'll not be an easy task. Besides,
why would they deliberately limit the upgrade path of this FBL unless it is in cooperation with beastx?
Just my conspiracy theory :-)
mayday1 is offline        Reply With Quote
Old 07-03-2012, 08:15 PM   #30
khogan
http://www.rcgroups.com/forums/showp...&postcount=238
"I also want clarify a couple of things.
1. the HB800 currently does not support satellites
2. The HB800 currently does not support sbus.
these features will be coming later when we update the firmware ."
It sounds like they will update the firmware, and right now there is not futaba/spektrum support.
I think with these clone units they are already making them for so cheap they would rather just sell a new one instead of making firmware updates. I doubt microbeast is working with them to make a cheaper unit. My conspiracy theory is that the BeastX I have says made in Germany but where is the spektrum/beastx unit made? Probably China so they got their hands on some code and made this unit.
Old 07-03-2012, 08:50 PM   #31
mayday1
I've never seen a AR7200BX, but I think they are made in china, so may be the code
could be lifted.
But I doubt the firmware of the AR7200BX is from v1.0 instead of the latest version, further more
I suspect it contains a satellite inside rather than a full receiver. There is no point in converting
the digital channel data into a PPM signal and then reconvert it back to a digital value if I were
to integrate a receiver with a gyro.
I agree with you in that I doubt they are actively working on the firmware. If they did a clean room
implementation, why would they use v1.0 as target instead of v2.0 or v3.0? I some how they
got a copy of v1.0 firmware, without the source code it wouldn't be easy to hack in satellite support.
Old 07-04-2012, 05:49 AM   #32
koenigsegg
Does anyone have the pdf file?
3DX450A, 3000kv Scorpion, Castle ICE 50, HS-5065MG swash, Spartan Quark, Futaba S9257, Hyperion 3s 2500mAH, AR6200, DX6i, Align flybarless DFC/Tarot 2 blade tail, or CopterX 4blade/Heliartist 3 blade raised tail, Rotor Tech Carbons.
koenigsegg is offline        Reply With Quote
Old 07-04-2012, 10:18 PM   #33
Airman0386
Default Need advice on which to buy!
Which tail holds better?
HB800, Tarot XYZ, or the CopterX CX-3X1000?
Old 07-05-2012, 03:11 AM   #34
clicky
At least someone went some length to do different PCB - not just steal whole lot and package it in cheap plastic case. LOL :p
clicky is online now        Reply With Quote
Old 07-05-2012, 10:51 AM   #35
Stevemech
I couldn't resist, I ordered one to replace my cx3x1000(for sale cheap).I installed a Robird g31 on my Beam and couldn't be happier so I hope this one is similar.
Steve
Stevemech is offline        Reply With Quote
Old 07-05-2012, 11:10 PM   #36
Spork01
I will be doing a video tutorial on how to setup the HB800 very shortly
trex 250 beastx
Fusion 50 beastX
Old 07-06-2012, 08:13 AM   #37
Stevemech
Very cool, look forward to seeing your video!
Steve
Old 07-06-2012, 10:23 AM   #38
MTDV
I cannot believe that...a Beastx similarity..., and dirt cheap. I will get one eventually when I get a chance. Beastx is good but too expensive. A good clone is better.
Last edited by MTDV; 07-06-2012 at 10:25 AM.. Reason: Actually not a clone - it's similar.
MTDV is offline        Reply With Quote
Old 07-06-2012, 08:06 PM   #39
w4llet
does it have pyro compensation?
w4llet is offline        Reply With Quote
Old 07-07-2012, 12:00 AM   #40
Spork01
If you are referring to tail pre comp. This firmware version does not do tail pre comp. The next firmware version will support.
trex 250 beastx
Fusion 50 beastX
