Old 07-27-2012, 10:33 PM   #61
BARK
You are right Spork. Operates just like you said. I was'nt holding the button long enough for the light to go solid and enter the A-N menu.THANKS A MILLION!
I'll be looking out for the vid.
BARK is offline        Reply With Quote
Old 08-20-2012, 11:12 PM   #62
maverickk
Spork, any update on the video? I just ordered one from Hobby Cool and a setup video would be great. Thank you.
RC Heli Pilot = Control Freak
maverickk is offline        Reply With Quote
Old 08-20-2012, 11:19 PM   #63
Spork01
I'll start uploading a few videos in the morning. Sorry about the delay.
Trex 450 Pro V2 FB spartan quark
trex 250 beastx
Fusion 50 beastX
Spork01 is offline        Reply With Quote
Old 08-21-2012, 11:17 AM   #64
jburg
Default Fixed Pitch
Has anybody used the hobbywing or BeastX on a fixed pitch setup? I've built a 450 with the funcopter fixed pitch head and not sure what to do with the "pitch" setups. There is the 6 degree setting and the max pitch setting.
jburg is offline        Reply With Quote
Old 08-23-2012, 10:52 PM   #65
maverickk
I am using Emax ES08MD servos for my cyclic - here are the specs:
Speed: 0.10/0.08 sec/60°
Torque: 2.0/2.4 kg.cm 27.8/33.3 oz.in (4.8V/6.0V)
Size: 32x11.5x24mm 1.25x0.45x0.94in
Weight: 12g 0.42oz
Dead Band Width: 1usec
Any recommendation what to set the Swashplate Servo Frequency to?
Old 08-24-2012, 01:41 PM   #66
Gopher7
I just put this system in an Align SE V2 and am very happy with it. The Hobbymate works very well..
Gopher7 is offline        Reply With Quote
Old 08-27-2012, 06:54 PM   #67
Spork01
here's step A-D. i'll upload more videos as they are done.
trex 250 beastx
Fusion 50 beastX
Old 08-28-2012, 02:13 AM   #68
dna001
Nice, but all I get is (This Video is Private) :-(
T-Rex 700N LogicTech 6100----Chaos 700FBL KDS Ebar
T-Rex 600N FBL OS55--------T-Rex 550FLB Spartan VorTex
T-Rex 450-6S BeastX ----- Blade 130x ---- Nano cpx BL -- McpX BL
dna001 is offline        Reply With Quote
Old 08-28-2012, 07:25 AM   #69
Spork01
It should work now, sorry
trex 250 beastx
Fusion 50 beastX
Old 08-28-2012, 03:30 PM   #70
Spork01
I'll load more videos as time allows
trex 250 beastx
Fusion 50 beastX
Old 08-28-2012, 08:34 PM   #71
Airman0386
Would you like help?? I can make some vids maybe starting at the other end of the instructions...
I just went through the whole setup process with my friend and we got mine working flawlessly.
Here are some more videos. I was a little nervous doing these, and talking, controlling heli, thinking, and videoing at the same time was hard
But hopefully they help.
You should be using these videos in conjunction with the BeastX V1 Setup Manual, as well as a pitch gauge
If you get confused on a step, read the manual and watch the video, and between the manual and video you should be able to see what the words in the manual actually mean.
Step 9 - Letter I
Swashplate Mixing/Servo Direction
*Servo reversing might be necessary to get this one right later. What you are looking for is the correct servos moving to your inputs, direction isn't important yet.
Step 10 - Letter J
Swashplate Cyclic Pitch Adjust
Disclaimer - this is what I interpret the reasoning for this setting as. Not sure how accurate my interpretation is. But the method is right
Step 11 - Letter K
Collective Pitch Limit
Step 12 - Letter L
Swashplate Travel Limit
FYI - Per the BeastX V1 manual, you should leave it on Blue!!!! Only reason the other options exist is IF you do bind. If you don't bind at blue, leave it.
Step 13 - Letter M
Swashplate Sensor Direction
Step 14 - Letter N
Pirouette Optimization
mCP X - 130X - 250 FBL - 250 FBL #2 - 450 Sport V2 FBL - 450 Pro FBL - X5 - DX6i
Airman0386 is offline        Reply With Quote
Old 08-28-2012, 08:55 PM   #72
Spork01
absolutely! your help is greatly appreciated.
trex 250 beastx
Fusion 50 beastX
Old 08-28-2012, 10:57 PM   #73
maverickk
Spork, I ordered the HB800/450 DFC combo from HobbyCool. Will the stock Pro swash work with this or do I need to order a special one as shown on Gopher7 post?
Thank you
Old 08-28-2012, 11:09 PM   #74
Spork01
The stock pro swash will work. i do like the dfc swash better tho
trex 250 beastx
Fusion 50 beastX
Old 08-28-2012, 11:27 PM   #75
Rustynail
Hi spork what do like about the DFC swash better than stock? If you don't mind me asking.
Rustynail is offline        Reply With Quote
Old 08-29-2012, 04:26 PM   #76
Spork01
the DFC swash is built/design for the DFC head. the links from the grips to the swash is much better supported. the chances of the links popping off is also drastically reduced while using the DFC swash.
Name:	dfc swash.jpg
trex 250 beastx
Fusion 50 beastX
Old 08-29-2012, 08:30 PM   #77
maverickk
Spork,
Thanks for your answers, this is very helpful. My DFC head did not come with a feathering shaft, will the pro shaft work or do I need a Align/Tarot DFC feathering shaft?
Old 08-29-2012, 08:38 PM   #78
Spork01
Originally Posted by maverickk View Post
Spork,
the DFC head uses the stock pro feathering shaft.
trex 250 beastx
Fusion 50 beastX
Old 08-30-2012, 05:44 PM   #79
Yamahajrp
What is needed to work with a spectrum transmitter?
130x stock
MCPx - Sold
Sent from my iPhone
Current: 130x, CopterX 450 Pro FBL*Build in Progress*
Gone With the Wind: MCPx, E-razor 450, Nine Eagle Bravo SX
Yamahajrp is offline        Reply With Quote
Old 08-30-2012, 05:55 PM   #80
Spork01
130x stock
MCPx - Sold
Sent from my iPhone
Any spectrum rx will work
trex 250 beastx
Fusion 50 beastX
