Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > JS TZ-V2 Frenzy
JS TZ-V2 Frenzy JS Models TZ-V2 Frenzy Helicopters Discussion
Old 05-28-2012, 07:11 AM   #1
rcjames
Default I'm getting my first JS TZ-v2 .50 heli as my 2012 build project
Hey guys. I'm ordering my first JS Model TZ-v2 .50 heli. I have not heard much bad things. I'm ordering probably the middle of this week. And hopefully maiden it on Sunday. I've been in this hobby for a while now. I wont have no trouble at all. Just one of those things that it's time for a project. It's the first build project for this year. Can't wait to get her in the air. Soon I'll get their 90 size. 239 at hobby king. I have few question though.
1. Is there anything you changed to improve?
2. How she flew compare Trex 600 since it's 2 lb heavy?
3. Did it came with metal tail case?
4. Can you answer these question for the 90 size?
Thanks!
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is offline        Reply With Quote
Old 05-30-2012, 05:46 PM   #2
ebonicrobot
The 90 comes with a metal tail case. Its super stable in the air and the only things ive replace are the clutch liner, and the plastic fan, ... I've replaced it with a raptor 90 CNC fan. I had a problem with the gear mesh so I had to shim the engine when mounting it. Now its smooth as butter. Oh replace all the fuel tubing the stock crap sucks.... made me overheat! Other than that i think its a pretty badass heli.
Avant Aurora FBL, YEP 120/700MX 510kv, Cyclic S9255 CGY750/9254
JR NEX E8, YGE 90/700MX,Cyclic DS610,BeastX/DS650
Trex 450 DFC 3S, YEP 45/450MX,Cyclic DS95i(clones), BeastX/8910a+,
Frenzy 90(UNDER CONSTRUCTION)
ebonicrobot is online now        Reply With Quote
Old 05-30-2012, 11:19 PM   #3
rcjames
Very cool yea I'm selecting haynes, os bubbless and many small things for it.
Old 06-02-2012, 04:41 AM   #4
mattsergo60
1.) I installed a Klone vented clutch bell, and Thunder tiger main gear (50)
I also installed the Thunder Tiger Fan on my 90 but had .090" machined off for a perfect fit (90)
2.) I feel as though they fly and track better ( than trex 600) which is the reason for selling my trex and getting another frenzy. ( lighter is not always better )
3.) Did not come with the metal tail case (50) although my 90 did ?
4.) The 90 had some problems ( which may have been fixed) one was with the tail rotor and it's cause came from 2 small screws holding the tail gear to the main mast. I drilled it out and used a through bolt. The other issue alot of folks seem to have is clutch alignment.
5.) enjoy !
2 -JR VIBE 50's---HK 600 GT---HK 450 PRO
FBL-JS TZ V2 50 TT---FBL JS TZ V2 90 w/ TOTAL G-- JS TZ V2 (belt)---Bell 222 FUSE with modified Voyager mechanics running a 6 cell LI-PO. and FBL !
mattsergo60 is offline        Reply With Quote
Old 06-05-2012, 03:36 AM   #5
rcjames
5.) enjoy !
Hi yup the 50 come with metal tail case. Over all I like it. This one guy that was my instructor really liked how it's built. But some ball links are to tight some is to loose. Over all I like it. The fan shroud should be thicker. It's to flexible.
Old 06-09-2012, 03:24 PM   #6
rcjames
Well I'm going to maiden her tomorrow.
Old 06-11-2012, 11:34 AM   #7
wishfull1
So how did it go?
wishfull1 is offline        Reply With Quote
Old 06-11-2012, 01:50 PM   #8
rcjames
Originally Posted by wishfull1 View Post
So how did it go?
I haven't maiden her because I couldn't find the tail guard. Over all it's a darn great kit for the money. I've built over 10 heli's and really like this one. But there is slop on the head which track down to swash. I'm buying a cnc swash and hopefully that will take care of the slop. I held very good the swash the moved my blade grip and no slop. So that should be replace. Anyway's people is blind not getting this one.
Old 06-22-2012, 10:18 PM   #9
rcjames
Here are some pictures.
Old 06-23-2012, 11:27 PM   #10
rcjames
Wow didn't notice about the flybar.
