| Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters |
can i use this motor ?
http://helidirect.com/scorpion-hk-32...is-p-25535.hdx right now i have a hyperion z3025-08 (970kv) motor and not sure its the right one for this heli. if i can use this hyperion motor what pinion sould i use?? right now i have a 24t and a 22t pinion. i also have a hacker a30-12xl (770kv) motor. what would be the best motor to use? and what size pinion to go with? o im useing 4cell batterys running a cc ine75 esc.
2-evo 50's>1-sdx>hawk pro bell 222 /3g/rjx>evo90>freya 70. trex500esp, scorpion/ ice 75/ 3g/rjx>hirboo embla 450 fbl,ice50,>lepton ex 2 bl mcpx's futaba 8fgs,,dx7,,phoenix v3.0r Last edited by 400 flyer; 06-04-2012 at 12:54 PM.. Reason: added info. |
anybody ??
2-evo 50's>1-sdx>hawk pro bell 222 /3g/rjx>evo90>freya 70. trex500esp, scorpion/ ice 75/ 3g/rjx>hirboo embla 450 fbl,ice50,>lepton ex 2 bl mcpx's futaba 8fgs,,dx7,,phoenix v3.0r |
Hi,
Sorry to have missed your post earlier. Is there a problem with the 970kv motor you have? Ideally you should use lower kv rating to run motor near 100% throttle, but that's not absolutely necessary. Just more efficient. check out the head speed calculator and play around http://heli.dacsa.net/calcv3/Default.aspx I run a Strecker 1150KV motor on 4S 20T but have to keep the throttle down around 60%. I don't do 3D. Mainly don't worry about it! Ciao, Bob |
That motor should work fairly well - with a 22T pinion
Either use the ESC governor or a flat 85%~90% throttle curve
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4 Gryphon field rep |
