Go Back   HeliFreak > R/C Electronics Support > Hitec Radios > Hitec Gyro/Servos
Hitec Gyro/Servos Hitec Gyro and Servo Support
Old 06-05-2012, 07:48 PM   #1
FLAME747
Default Rebuilding Servos Yes or No
Hey guys, I have a pile of HS5085MG servos, they all have gotten that ratchet feel to em, due to crashing
I replaced all the gears with new one, applied ample servo grease, yet even with the new gears they are not like the new ones
Still has that ratchet feel
What do you all think?
Thanks,
FCA
My fantasies of flying a Heli, is better than the reality.
JR X9503.FunJet Ultra, Scimitar, Stryker F27C and Q, DogFighter, mCPx
FLAME747 is offline        Reply With Quote
Old 06-06-2012, 02:08 AM   #2
A.T.
Originally Posted by FLAME747 View Post
Hey guys, I have a pile of HS5085MG servos, they all have gotten that ratchet feel to em, due to crashing.
I replaced all the gears with new one, applied ample servo grease, yet even with the new gears they are not like the new ones. Still has that ratchet feel
What do you all think? Thanks, FCA
Metal gears are not perfectly round,
1. Rotate one or more gears slightly and try again
2. Ensure case is not overtightened
Servo - FAQ : Metal Gear Servos - DIY Repair & Extend MG Servo Gear Life Servo - FAQ : Metal Gear Servos - Why MG Servo have a Plastic Primary 1st Gear See also sub Section:
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
under
"Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline        Reply With Quote
Old 06-06-2012, 06:11 AM   #3
wanderer56
Also check the pivot points for the pins inside the case. They often get damaged as well and require a replacement case to repair.
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC
Trex 450 Sport-450M, 13T, RCE-BL35X, HS-5065MG, HSG-5084MG, DS760
DX8
wanderer56 is offline        Reply With Quote
