Go Back   HeliFreak > R/C Helicopter Support > Beam Avantgarde 600
Beam Avantgarde 600 Beam Avantgarde 600 Support Forum
Old 06-10-2012, 02:17 PM   #1
mejnertz
Default One way bearing on Avantgarde
Hi Beam dudes..
I destroyed my one way bearing on the Beam Avantgarde today, and wanted too put a new Owb in the autorotation case, but it had a loose fit and wouldn't stick in the case, do any of you know how to put this One way bearing into the case and make it stick??
My friend just tried to use green locktite, but it didn't hold
With kind regards
Benjamin
mejnertz is offline        Reply With Quote
Old 06-10-2012, 09:45 PM   #2
Rotosmasher
How hard was the old bearing to remove? Did the damage affect the case? Perhaps measure the outside diameter of both the old and new bearings as a starting point.
You are only as good as your next crash.
Rotosmasher is offline        Reply With Quote
Old 06-12-2012, 03:21 AM   #3
w_prasit
wait for a while ... Super BEAM E6 is coming
Thanks to BEAM deliverment team
w_prasit is offline        Reply With Quote
Old 06-13-2012, 01:08 AM   #4
Yoda DK
any info on that?
Yoda DK is offline        Reply With Quote
Old 06-13-2012, 08:25 PM   #5
Jamesppp
Is anything missing???
Name:	Beam AvanteGerde.jpg
ID:	324333   Click image for larger version
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900
Jamesppp is offline        Reply With Quote
Old 06-14-2012, 12:32 AM   #6
Yoda DK
?? there is not anything missing. the owb case expands under load.causing the owb to spin in the case. thats the problem Benjamin and i is having. the owb case in alu is to soft and wenn doing 3d it just expands and makes the owb spinning. this causes the heli to loose power and crash
heard that Beam is comming with a new owb case. but i'm not sure
Old 06-15-2012, 10:11 PM   #7
w_prasit
That's right !!!
Current oneway system will limit head speed not over than 2300 RPM, over than that oneway cannot resist if you fly hard 3D. but New oneway system will make BEAM E6 run on 2500 RPM without any issue. It will arrive to me on next week, I will show you soon
2300 RPM with stock BEAM E6, it also very good heli class 600 but for pilots who love high RPM, it's not enough. They want more RPM so BEAM engineer team develop new oneway to serve this target group.
Thanks to BEAM Team and Welcome you to Super BEAM E6 !!!
Old 07-15-2012, 05:45 PM   #8
audio131
Default bearing
my assembly that came in my kit was red. i see the replacement online is silver,,is that the better one?
audio131 is offline        Reply With Quote
