Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 06-17-2012, 02:31 PM   #1
xzodiackxs
Default TT 90 G4N or Align 600N ?
I 'm hopefully buying a new 600 sized nitro helicopter , debating between the trex 600N and TT g4N . What do you guys think i should go for . Im looking for power , stability and performance in 3d .
xzodiackxs is offline        Reply With Quote
Old 06-17-2012, 04:05 PM   #2
xzodiackxs
lol totally forgot g4 is not a 600 sized heli . But which one do you recommend .
Old 06-18-2012, 08:09 AM   #3
f2000ez
Default TT G4N
Go with the TT G4N. You can always convert it to electric. Stable and powerful machine.
f2000ez is offline        Reply With Quote
Old 06-18-2012, 11:43 AM   #4
xzodiackxs
Is it easy to convert it to electric ?
Because trex 600n is also capable of going electric .
Are there any other benefits the g4 has over trex ?
Old 06-18-2012, 08:44 PM   #5
rcflier1
if your looking at a 600 size, the x50 is the way to go imo, it walks all over the trex. mine is fbl with the ys56, fast and smooth.......
rcflier1 is offline        Reply With Quote
Old 06-19-2012, 08:20 AM   #6
f2000ez
Default G4 vs Trex600
The G4 takes about 30 mins to convert from nitro to electric
Old 09-10-2012, 04:26 AM   #7
feudallordcult
Hiya pls pardon my noobness but may I ask which parts do I need to buy to convert the g4 to nitro? I m thinking of buying one. Thanks in advance for advice rendered.
Trex700N LE, Trex600ESP,Mini-Titan & Trex250SE
Feeling of Hover at (28/12/2009) - PRICELESS!
Biggest mistake - selling my Beam...crap!
feudallordcult is offline        Reply With Quote
Old 09-26-2012, 02:27 PM   #8
ticedoff8
I think the G4 kit contains all the parts for electric or nitro.
Then, it would just be engine & engine support stuff
ticedoff8 is offline        Reply With Quote
Old 09-26-2012, 02:28 PM   #9
ticedoff8
I would recommend the G4 with the OS or YS 55-60 size motor.
It flies great - just a little slower.
Old 10-01-2012, 11:18 AM   #10
Konrad78
The G4 kit contains airframe only, no electronics. Recomended nitro engine is 90+
TRCHK
Konrad78 is offline        Reply With Quote
Old 10-12-2012, 03:36 PM   #11
ticedoff8
The kit contains the airframe parts necessary to build either an electric power or nitro power version.
The "recommended" engine is a 91 - but people fly it with as small as .55 and as big as 1.20.
I've seen it fly with an OS .55HZ-DRS and it flew great - just not as snappy. It also flew for 15 min per tank. After 3 months of getting better better & better at 3D flying, the guy changed to an OS 105 and was very happy.
Cannot do that with a Trex 600n.
Old 10-15-2012, 03:28 PM   #12
Scooterpilot
the G4 is designed for a 90 size engine. The smallest engine I've seen in a G4 is a YS61 ST and the 3D school uses that motor in their machines. This engine had the same bolt pattern that 90 size engines have and can be mounted using the motor mount supplied in the G4 kit.
I've never seen a 55 size motor used in the G4. The bolt pattern on the motor is smaller than the motor mount supplied with the G4 kit.
Team Thunder Tiger
Raptor G4, CGY 750,YS120
Raptor X50 FBL, YS60SR, CGY 750
Raptor 30 FBL, OS37, CGY 750 12Z, 14SG, 8FG
Scooterpilot is offline        Reply With Quote
Old 10-16-2012, 12:18 AM   #13
NoBrakes
If you're referring to my G4 it had a YS 61 ST-2 in it, not an OS 55HZ-DRS. You may have been thinking of my Synergy N5C which has the OS in it. At about 1800 rpm I was getting just under 20 minutes of flight time still with fuel left in the header tank. Only flew that long when alone. I would limit it to a little more than half tank when the rest of you guys were there. After 12 minutes I could hear grumbling from the other guys waiting their turn.
NoBrakes is offline        Reply With Quote
