Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 06-20-2012, 10:15 PM   #1
minititinflyer
Arrow something to help with the heat on the motor plate
i just flew my gaui 425 and was waiting for the pack to cool down to store charge it. and was checking my temps on every thing. and saw the motor plate was building heat so help with it i made this. what you guys think? p.s they used heat sinks and i had to cut them to fit so sorry if there dont look high end shiney.
ID:	326022   Click image for larger version
blade msr!, blade mcpx! ,blade 130x!, trex 250!, ,mini titan e325 v2! ,gaui hurricane 425e! ,trex 600 esp!, trex 700e! ,Hitec Aurora 9!, spektrum dx6i!
(Mr.heli)
minititinflyer is offline        Reply With Quote
Old 06-21-2012, 09:20 AM   #2
pug907
Good Idea and a simple solution.
As long as it works, does it really need to be shiny shiny?? Let's face it, who's gonna see it 50 foot in the air?
Cheers
pug907 is offline        Reply With Quote
Old 06-21-2012, 12:18 PM   #3
minititinflyer
ture. and it dose work for me it cool off the motor and mount. today i tested it. for me it dose work alot faster and the motor stayed a bit cooler and the mount stays cooler too im USA FL. the temps 83f . the humidity is high like alway. which dont help but it works and i made a set for the other haft of the mount the temps on the mount used to be 145f now its 130f the motor used to be 157f now it 148f to 150f.
(Mr.heli)
Old 06-22-2012, 06:53 AM   #4
stark
Some other things you could try to improve motor cooling.
  • Mount the battery pack under the frame
  • Make an air vent in the canopy to increase airflow to the motor
-roger
Compass Atom 500 FBL, GAUI hurricane 425EP
stark is offline        Reply With Quote
Old 06-23-2012, 10:56 PM   #5
minititinflyer
well so far this little mod helped me out alot
(Mr.heli)
Old 06-24-2012, 06:21 PM   #6
papa38
Ya, I run my batt on the bottom. 2650 6 cell, with the Turnigy 1600kv motor. (no canopy vent) Half the time, I'm not running with a canopy on anyways
papa38 is offline        Reply With Quote
Old 11-08-2012, 11:54 AM   #7
Don_N
Default Heat Sink Efficiency
Something to think about is that heat sinks radiate heat better when black than when shiny. It's not intuitive, but a black painted heat sink actually eliminates heat faster than a shiny silver one!
Cheers
Don_N is offline        Reply With Quote
Old 11-10-2012, 10:50 PM   #8
minititinflyer
thanx i'll look in too that
(Mr.heli)
Old 11-11-2012, 04:45 AM   #9
sp00fman
Black heatsinks are only better for passive heatsinks. They rely on emitting the heat energy as infrared light. When air is forced over the fins it is actually the contact between air and heatsink that is transferring heat away. Making it black will have a negligible effect as the motor is spinning air over the fins.
FBL clone 250 + 450's - with CX-3X1000
FBL GAUI Hurricane 425 EP with ZYX-s -=- GAUI Hurricane 520mm - bell/hiller mixed paddled stabilization
The more money you have up in the air, the less you love it...
sp00fman is offline        Reply With Quote
Old 11-11-2012, 10:58 PM   #10
minititinflyer
well i havent painted it bc its bin working for me
(Mr.heli)
