| Mikado Logo 800 Xxtreme Mikado Logo 800 Xxtreme Helicopters Discussion |
Question;
How do you hook up the WR BEC to the VBar on the XXtreme ? Do you drop the "red wire" from the YGE ESC ?
Trex 550-DFC/IKON, Trex 560-DFC/IKON, Trex 600EFL-DFC/IKON, Trex 700HV-DFC/3GX, Logo XXtreme-VBar DJI-Flame Wheel 550-Naza/GPS, Haiyin Batteries, Spektrum DX8 |
You dont Need to Cut the red wire. The yge has no bec.
Thank You
Hello,
is it better to connect the WR BEC to one of the 7S Pack or to the whole 14S? I heard something, its less work for the BEC if its just to one of the packs connected. thank you, faxxe
Logo 800 XX / 5035 / YGE 160+ / S9352hv_BLS256 / Vstabi5.3xx / Edge 813 Raptor e720 / 4525-520 / Fusion Hawk120 / BLS452&251 / Vstabi5.3 / DH 711 DX18 & IISI |
14s stresses the bec a Little more, but less Chance of Hooking it up wrong And frying your Electronics afaik.
Greetings |
#6 |
I used a 4S lipo flight pack insted of hooking it up to the flight batteries. but if I was going to connect it to my flight packs I would piggy back a pigtail off one of the 7S packs to eliminate a jumper between the two packs.
#7 | |
@faxxe: I have my WR BEC wired up to one of the 7S packs so the BEC is just reducing voltage from one pack instead of the full 14S. One added benefit is that all of your electronics will be powered up before your ESC and motor gets power. Just remember to plug in the 2nd pack. During my maiden, I forgot to plug in the 2nd pack and of course... once I flicked off throttle hold, nothing happened and then I was stressed that I screwed something up.
Then I realized that I forgot to plug in pack 2 and all was well.Read the post below because it's important to know which connectors to connect to the BEC (the one that connects to the negative lead of the ESC). If you connect the BEC to the wrong connector, you will fry ALL of your electronics!!! (Sorry for the big type, but I'm trying to keep you from having a magic smoke party). Quote:
Banshee #48 | Henseleit TDR | Minicopter Diabolo | Triabolo | Kasama Dune | Synergy E7 Mikado Logo 600SX | Logo 600 SE - Mikado Hughes 500 Scale Fuselage | Logo 800 XXtreme |
#8 |
Great help.....many thanks!
-faxxe
#9 |
I am using 14s to power my wr bec. I have no problems in the complete season.
#10 |
More than that: . If this ESC is like the yge 120 HV it needs power from that red wire from the red wire or it won't arm, since the BEC is wired to the vbar, the red lead on the throttle is hot, the ESC uses that power. At least that's how the 120HV works and I think the 160 is the same
Not sure about this, but I think it uses the voltage from that line to power the opto coupler in the ESC ( since there is no BEC in the ESC, there is not suitable voltage level for the optocoupler) |
