Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Heads and Rotor Blades
Heads and Rotor Blades Heads and Rotor Blades Discussion
Old 06-26-2012, 02:01 AM   #1
Capt. Speirs
Default 450 size 4 Blade Tail Rotor Blades
I decided to go with a 4 bladed tail rotor to get my tail authority with my 5 bladed head assy and I have looked and I can not find any 450 Size "Scale" Tail Rotor Blades. Anyone know if there is such a thing? Thanks for your time.
Blade 400/450 Frankenstein for scale project.
Trex 450 Sport V2 for scale project.
Trex 700E V2 for scale project.
Capt. Speirs is offline        Reply With Quote
Old 06-26-2012, 05:36 PM   #2
bladerunner469
Here u go http://www.cnchelicopter.com/servlet...hdx-3dx/Detail
Bring it home in one piece 2 MD500E B400s/ 450 BO105/ B400 BELL 222/450 Hughes 300 / UH-1 Huey B400/A109 Belt CP/ AS350 450/ 2 Jetrangers 450s Love them All
bladerunner469 is offline        Reply With Quote
Old 06-26-2012, 06:13 PM   #3
Super-Hornet
I think I have the same..if not, very similar design as posted. I used it in my Pavehawk.
If it is the same, then u might want to take a look on the pitch range. I used it in my Pavehawk with main rotor spin at CCW rotation and with tail on the right spinning upward (just like in real Pavehawk) and it suffers from uneven pitch range throw. In the end, I modify the linkages in order to have equal throw.
SH
Super-Hornet is offline        Reply With Quote
Old 06-26-2012, 07:30 PM   #4
KevinMc
You can also go the DIY route. The attached photos show my solution for a scale "stacked" tail rotor assy for a TREX 450 (SE V2) with a torque-tube tail. These mechanics will make their way into an MD-500 body I've got but I've been having so much fun flying the mechanics that I don't want to take it "off-line" to put the fuse on!
ID:	327358   Click image for larger version
ID:	327359   Click image for larger version
ID:	327360   Click image for larger version
Kevin McLeod
GAUI 200 EX V2 FBL, TREX 450 SE V2 FBL, mCP-X.
KevinMc is offline        Reply With Quote
Old 06-26-2012, 11:30 PM   #5
Capt. Speirs
Originally Posted by bladerunner469 View Post
Not quite sure what you are showing me here, I see the AH56 Cheyenne with the scale tail rotor blades I am looking for but where can I get them?
Old 06-26-2012, 11:52 PM   #6
bladerunner469
Ok are u looking for tail blades or a tail rotor. Because the link i put on here is for a four bladed tail rotor
Old 06-27-2012, 03:58 AM   #7
Andy01
I thought the first post clearly said blades.
Why not just use normal plastic blades (like KDBB) and paint them ?
Colin
Vario Long Ranger 700e
Seahawk 600
UH-1N 500
Baumann EC-145 800+ (coming soon )
Andy01 is offline        Reply With Quote
Old 06-27-2012, 07:30 AM   #8
Desert Fox
Default scale tail blades 450
Capt. Speirs
RC Aerodyne has scale tail blades for a UH1 heli 450 size with the purchase of main blades
http://www.scaleflying.com/
Cheers!
Desert Fox
Spektrum DX6i, Blade SR, 5 Heli-Max AXE 400 3D, RC Aerodyne EC145 EXI 450 Pro Belted CopterX Floating Head
Desert Fox is offline        Reply With Quote
Old 06-27-2012, 08:39 AM   #9
bladerunner469
Yeah i guess i should have payed closer attention
Old 06-29-2012, 11:38 AM   #10
Capt. Speirs
Originally Posted by Desert Fox View Post
Capt. Speirs
Cheers!
Desert Fox
I contacted RCA and they said they could not break up the set. I don't want to have to pay $50 for a set of tail blades. Anyone need UH-1 main blades, maybe we can go in a couple of sets.
Old 06-30-2012, 12:40 PM   #11
JCUNNY
Why don't you just use the 450 Pro style tail blade? They are readily available and look pretty close to the part.
JCUNNY is offline        Reply With Quote
Old 06-30-2012, 01:14 PM   #12
drakonis
i use the pro style blade on my md530. painted up to look scale. cant tell the difference.
drakonis is offline        Reply With Quote
Old 06-30-2012, 03:51 PM   #13
Capt. Speirs
Will they be too much or can I cut them down? Remember, I would be using 4 of them.
Old 06-30-2012, 04:08 PM   #14
JCUNNY
I use three on my setup. Remember, the tail will only "use" what it takes to keep her straight. This will just make it easier for your tail servo, as it wouldn't take that much movement to get the tail to move..
Cutting on them will just decrease thier effectiveness.
JC
Old 07-01-2012, 08:19 PM   #15
Capt. Speirs
JC
Thanks everyone for your input, I will check my LHS for those blades.
Old 07-02-2012, 10:56 AM   #16
SidewaysLS4
+1 on the Pro blades, got 4 running just fine on my 4 blader
SidewaysLS4 is offline        Reply With Quote
Old 07-02-2012, 01:20 PM   #17
drakonis
these guys are correct. the tail will only use whats needed. pro blades are readily available and most shops that carry align.
on a side note, if you do paint them please use an airbrush and paint them very lightly. i think i slightly thinned the paint so it would flow thru the brush. then just did 2 light coats as to not add too much weight to the blades and get good coverage. what ever you do, dont try to brush paint them. one. it looks terrible (ive tried) and two it add way too much weight to the blades.
Old 07-03-2012, 05:43 PM   #18
Capt. Speirs
Picked up the last four blades they had in stock, thanks for the advice on painting. I was going to use my airbrush with Tamiya paints, they go on real thin and very durable.
