| Titan X50E Thunder Tiger Titan X50E Helicopters |
Scorpion 4025-890 is being installed and the holes do not line up in the frame for the motor mount...it seems like a spacer is needed like stated in the manual, so have you guys installed yours? I can flip the pinion support upside down and it goes in fine and the pinion can be adjusted but not sure if thats ok to do?
Raptorzz,
I forgot to mention that you would need that spacer when I posted my setup. I turned the motor support upside down as you mention until I got my motor spacer. I flew it this way for about 4 flights. I think the worse thing that can happen with it this way is to lose the bearing out of the support housing. Charlie |
Sweet! Thanks for the info. Im gonna green loktite the bearing in and roll with it!
Had mine setup with support housing upside down. The bearing did fall out after 6 flights. Guess I will be putting in the spacers! I haven't done anything but hover with the heli but it sure ran smoothly!
The heck with the support..just flying without it! This heli flies so darn great i love it
