| Beam Avantgarde 600 Beam Avantgarde 600 Support Forum |
i really need a 14t pinion to make the head speed i want using a cc80hv gov.. will a logo pinion mesh with the avantgarde gear?? i wish beam would make a 14t and 15t pinion...
Yeah that is a bit weird, 12t, 13t then straight to 16t?
It just limits your motor KV choices I guess.
Team Old Mate - He's a good bloke |
true ,but i only had a 600mx and a 700mx motor.
Will the 700mx motor fit?
. Futaba 14SG, Thunder Tiger Titan X50E, Blade Nano CPx (2),.Beastx, TP 2 2700 65C, POWER LAB 6 |
hi. i think itwill fit if u dremel the frames towards the gear side. about an 1/8.. i went with the 600mx first because i wasnt sure of the balance points yet.. it maybe too nose heavy with the 700mx depending on lipos used .. can always use stick on weight on the tail to campensate,,,,,UPDATE---700mx fits with out mods .expect needing to drill motor mount to make the 4mm bolts fit
#6 |
really need a 14t pinion for the avantgarde,,beam please make one
#7 | |
Sorry for the many questions, I guess without not seeing it I dont undersand how you drill the motor mount the make the 4mm bolts fit? Could you please give a little more detail? What pinion are you using with the 700mx?
#8 |
that motor mount was made for a 600 sized motor which the bolt pattern uses a 3mm bolt,, 700mx motor uses 4mm bolts to attach to a mount,, so just drill out the mount till u get the 4mm bolts to go thru it and into the 700mx motor.... used the stock 12t pinion..flat line throttle curve. the pinion is no high enough to run cc gov,. rreally a 14t is needed..
#9 |
Will cc ice 2 80 hv handle 700 bx
#10 |
on a 600 ship. no problem
#11 |
