| JS TZ-V2 Frenzy JS Models TZ-V2 Frenzy Helicopters Discussion |
Hello all HeliFreak-aZoids,
I am trying to source out the correct parts for my TZ V2 50 and am not exactly sure which Raptor50/30 versions I will need to replace the clutch and one way starter bearing. I have been through two TZ starter shafts and clutch/bearings now to try and stop the OWB from slipping on the shaft when starting the motor. Have tried 3 different lube variations also. Firstly with no oil or grease at all, Didn't stop the slipping. Then with grease but to no avail. And finally with just two drops of light oil. Neither of these options seemed to have stopped the starter shaft from slipping at all. The V2 starter shaft is 8mm so am I correct assuming that if I change the clutch to a Raptor 50 (part #PV0359), then I will also need to change the starter shaft to a Raptor 50 (part #PV0360)? If this is the case do I also need the Raptor 50 clutch bell and pinion or can I keep the JS Model parts which are still in good shape? Also, can anyone confirm if the Raptor pinion will screw straight into the JS bell? Or are the dimensions and bearing sizes completely different? Really all I want to do is install a starting train that won't slip. Any clarification from experienced flyers about the minimum parts needed would be great. Many posts online mention replacing the clutch but aren't very specific with which version part (ie: Raptor 50 or Titan X50 bell). Again have assumed that the Raptor 50 V2 is where the compatibility is. Many thanks Steve Last edited by eluminous; 07-18-2012 at 07:21 AM.. Reason: Typo's and additional clarification |
