| 300X Blade 300X Helicopters Information and Help |
#161 |
Test flight after putting stock tail servo back on...Had everything set right except one thing and that was rudder in transmitter setting..Needless to say I crashed!!!
">Here is video of my friend filming (Language Warning At End) And here is Onboard (Volume Warning) Can you believe the only damage was a stripped Ball that goes into the blade grip...No other damage!!! Last edited by AThom; 06-04-2013 at 01:46 PM.. |
#162 |
This is the second flight, after I rebuilt with the Lynx slant gear and 10t pinion on the stock motor and ESC. The BeastX unit has been moved to the top deck, after which I did a test hover, but no real flying. This is also running with MicroHeli carbon fiber blades designed for the Blade CP/SR, and the Lynx frame stiffener. I had such a rush, and was so thrilled with how it was performing I decided to try some things I really shouldn't have, leading to the conclusion. The first time I spooled it up today, it had a mean tail wag, which was eliminated quickly by reducing the Gyro gain from the factory recommended 77% to 65%. Tail locked in.
Damage report: Belly Flop. Head bolt snapped in three pieces. One of the carbon blades is compromised. Landing gear broke, and I stripped the left aileron servo. I had parts on hand to fix those, and got that taken care of last night. I have not checked the lower main shaft bolt, but it's still on the bench, that will get looked at before the next flight. Fortunately, no tail damage, but I'll have to reset my pitch. This flight gave me great confidence in my setup skills, as I've never worked on a heli this size before, and it flew great! I had to rebuild following its Maiden flight crash. Can't wait to get back up in the air. Now that I've proven I know how to turn a screwdriver, my flight skills could use some practice.
Blade mCX2/mSR {x2}/Nano QX/120SR/mCPx(v2+BL {x2})/CP Pro 2(Scale Build in Progress)/300x - Spektrum DX6i
Syma s107g / Xieda 9998 (x2) |
#163 |
put it back together about a week ago remounted the beast up top .should change the tail hub and shaft
#164 | |
BLADE 300X, MCPX V2 BL, Nano CPX, CX2, MCX, Mini Pred, Hubsan X4 Quadcopter, DX7s |
#165 |
june 12th will be my one year aniversary of flying helis. i just want to pitch pump my mcpx into the sky until i cant see it , i love helifreak ,
#166 |
Once I get this keychain cam figured out I will post a vid or two.
#167 |
#168 |
When I push the power button the led comes on solid. Then it blinks 5 times. I may have got a dud.
#169 |
All you should have to do is press and hold power button till led goes solid then press and hold record till you get 3 blinks then it is recording..
I can not replicate it on my keychain... |
#170 |
#171 |
Another On board with music
#172 |
the little capacitor on my e flite esc fell off and my hobby shop had a castle ,my don s motor should be here very soon
#173 |
Here's a flight with the castle in it before I had it governed I was running flat 85%
500 pro AR7200BX Min Air furion 6 |
#174 |
i dont know enough to make it run in governor mode .and is it imperative that i use it??
#175 |
