Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 07-29-2012, 02:26 PM   #1
donskills
Default GT5 in TDR questions
Greets! I switched out my black full sizeVBar in my TDR for a GT5 a little while ago and I am really loving it.
I do have a couple of questions and wonder if anyone is in the know?
I just unplugged my servos and rx (SBus) during install and the center on all my cyclic servos seemed on par,as do the end points. I took for granted that the tail servo worked the same but when setting endpoints for the tail servo I got quite a big difference! I am around 120 in one direction but over 200 in the other. Piro consistency is good but I wonder if anyone else got similar results or did you reset the servo horn?
Also, I have a slight bounce on piro stops that I can't get rid of. My P gain on tali is 75 and I gain 65. Any higher and the tail starts oscillating during sideways loops etc. I have tried different D-sense values from 5-50 but cant get rid of it. I am at 5 now as the bounce is the smallest at this value. I am using BLS451/251 servos. Tried a bit of smooth stop today too but it did not help.
Any suggestions to help get rid of the bounce?
Henseleit TDR 2011,GT-5. BLS451/251, Pyro 700-52, Jive80HV, Radix 710FBL, Radix 110 tails
Compass Warp 360, GT5, MKS 92/8910, Edge 60 tails.
Phoenix R/C, Futaba T14MZ
donskills is offline        Reply With Quote
Old 09-14-2012, 08:02 AM   #2
Daniel tengvall
Adjust your pushrod until you got similar "bounce" on both CW and CCW, the adjust D value.
Daniel tengvall is offline        Reply With Quote
Old 09-17-2012, 06:19 AM   #3
swalko
When i used G-T5 in my TDR travels to both sides was equal (tail slider in middle as is described in TDR manual). I got best result with this tail settings:
P 99
I 90
D-Sense 0 (any other value than 0 caused bounce on stops and wag with much lower P and I values)
Tail stick dynamic 30
DMA cyclic 5
DMA pitch 65
Tail-D-DB 5
Tail symmetric 0
Smooth stop 0
swalko is offline        Reply With Quote
