Go Back   HeliFreak > R/C Electronics Support > Hitec Radios > Hitec Gyro/Servos
Hitec Gyro/Servos Hitec Gyro and Servo Support
Old 07-31-2012, 04:09 PM   #1
brettskywalker48
Default 5084 MAX TEMP?
I just installed a 5084 with an assan ga250, I'm not running it at 333hz which it is listed under for fear of frying my brand new servo. I'm running it at 1520us/250hz, had my 2nd chance to test fly today. After 5 mins of stall turns & a few slow fig 8s I immediately took the temp of the servo because it was a lot hotter than my 1st test with the new gyro/servo combo, it was near 150 degrees!!!! I've heard the 5084 can run WARM, but is 148-149degrees too hot? Should I use the 333hz setting or stoop down to 70hz? What good is haveing a rudder specifc servo if I have to run it near analog speed??
brettskywalker48 is offline        Reply With Quote
Old 08-01-2012, 04:12 PM   #2
A.T.
Sorry, I do not have the specifics here today but would not let any servo get that hot.
For best information, suggest email question direct to:
Hitec Warranty & Service
Note: Hitec USA only services North/South America and Canada. (- Closed Weekends)
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline        Reply With Quote
Old 08-01-2012, 08:27 PM   #3
brettskywalker48
I emailed hitec this morning & got a reply from a rep in less than an hour. He said the correct gyro setting 250Hz & check mechanical, & should NOT get that high of a temp. I'm lucky its still alive! I double checked the gyro settings & sure enough it was set wrong to 333Hz, think I got confused after toggleing the gain switch so many times & I was actually in the DELAY setting. I ve reset it to 250Hz, was hoping to test tonight but the wife had to go to the store & my daughter is sleeping. I also was able to make a nearly perfect straight line with the tail pushrod, wasn't off by much but I ll see how she flies as soon as I can
