Go Back   HeliFreak > R/C Electronics Support > MSH Brain FBL Unit
MSH Brain FBL Unit MSH Brain Support Forum
Old 08-11-2012, 11:28 AM   #1
Fabien
Exclamation Brain Wiring Diagrams
Hi,
Here are a few Diagrams for wiring, hope this helps
Standard Receiver ( PPM )
Futaba S-Bus Receiver
Spektrum Genuine DSM2 and DSMX Satellites
Last edited by Fabien; 08-11-2012 at 04:03 PM.. Reason: Adding S Bus+ Spektrum Diagram
Fabien is offline        Reply With Quote
Old 08-11-2012, 01:54 PM   #2
Jason O'Connell
Formerly BarnStormer
Great job! Thanks. It is good to see the servo layout when pluging them in. Less confusion as to where servos 1, 2, and 3 should should be located.
Team Compass USA
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote
Old 08-24-2012, 08:08 AM   #3
Rossco
Great diagrams Fabien,
I have the Brain connected with the Spektrum AR7100R and i'm find that the system retains power when switched off and i can't seem to find a reason why.
I am running straight Lipo 2S voltage to everything and i'm running a Futaba voltage step down for the tail servo which is connected inbetween the Brain and servo.
I assume that even though the RUDD/AUX2 outputs from the AR7100R are 5.2 regulated that the Brain will supply the straight 2S lipo voltage to everything?
Thanks!
Rossco (Team Synergy UK)
Rossco is offline        Reply With Quote
Old 08-24-2012, 08:21 AM   #4
Fabien
Hi,
mmm it depends on how you wire the unit.
If you have direct HV output for cyclic servos and low voltage output ( 5.2V f) for tail, then the best is to use only the HV wires on the receiver side to power the Brain and make sure to have removed the tail " + " (red) wire fromt he plug so it does not feed for example HV throught he elevator connector and in adition 5.2 V via the tail.
I will check the exact spacs of your receiver and will make a wiring diagram tonight for you,
Best regards,
fabien
Old 08-26-2012, 10:37 PM   #5
sixback
Online look at HV BeastX wiring setups posted here on Helifreak. You would normally split the signal wires off the cyclic leads so that you have 7.4v going to your cyclic servos only. The Brain + tail servo would be powered from the regulated 5.2v side sending just signal to the cyclic. Common ground is maintained through the battery. You might have to use the aux channel and the tail channel to power the Brain for redundancy.
sixback is offline        Reply With Quote
Old 08-29-2012, 06:50 PM   #6
Fabien
Hi,
sorry for my late answer.
As you have a stepdown regulator between the Brain and the tail servo, you have to remove the red wires on the AUX 2 and RUDDER lines between receiver and Brain, so all servo bus is powered staight from the 2S lipo and the tail servo will be happy with the step down regulator.
On another hand, for that kind of configuration, you can also get rid of the 7100R as it is just useless here for that configuration ( as you can not use the 5.2v regulated outputs), and use satellites instead on the Brain
You will then just need to keep the stepdown between brain and tail Servo.
Most important is to keep signal and ground wires ( normally signal sould be enough but by precaution only remove the 5.2 V red wire) betwen AR7100R and BRain if you keep the receiver
BEst regards,
Fabien
Old 10-16-2012, 11:49 AM   #7
wbefield
I'm going to put a Brain on my Synergy N5C and will be running HV to my cyclic and tail servos with a Gryphon Duo regulator for my throttle servo. It's my first nitro and have never used a regulator. I didn't find any documentation on the Gryphon Duo. Does the regulator simply plug in between the Brain Throttle output and throttle servo?
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Reply With Quote
Old 10-16-2012, 10:52 PM   #8
Tommy Wagner
You are going to have to run the power and the ground to the regulator and the signal wire to the brain. Otherwise the HV will also go to the throttle servo from the brain.
Tommy Wagner is offline        Reply With Quote
Old 12-30-2012, 09:33 AM   #9
andygi
hi to help everyone could the moderators please sticky this thanks andy
andygi is offline        Reply With Quote
Old 12-30-2012, 12:50 PM   #10
GRIMX
All these diagrams are located in your Brain software, Basic Wizard step #3 "Receiver Configuration"
GRIMX is offline        Reply With Quote
Old 12-30-2012, 06:05 PM   #11
andygi
hi yes it is located in the software but why not sticky it for a quick reference for the guys that have a problem and come on asking for help and a diagram.
as fabien took time out to do them for the first of us to use them on first release especially as he doesn't work for msh is bit of a waste, these pictures are as good to the newby as his tuning guide is to the more experienced.
andy
Old 01-26-2013, 12:57 PM   #12
WonderedUnder
just wanted to say that I think it's hilarious how i stumbled onto this thread. I'm a neuroscientist and am just doing some basic research on the internet. and Voila! a Helifreak thread pops up at work! I can't escape you, Helifreak!
Brain wiring diagram. LOL!
WonderedUnder is offline        Reply With Quote
Old 01-27-2013, 02:56 AM   #13
d.porte
Hi, i will use a voltage regulator from Gryphon.
Should i remove the red wire between reg and ikon for servo 1, 2, 3 and only provide power on CH3/SREC or should i keep all the red wires and provide power width CH3, SRV1, 2, 3.
The Cyclic servos will be powered by the reg (6v) and the tail servo directl by the brain (5.2v).
Thank you for your feed-back.
GOBLIN 700 competition / CC 160HV / KDE 700XF 495 / MSH Brain/IKON (ordered)
ALIGN T-REX600EFL Pro / CC 80HV+ / KDE 600XF-530 / MSH Brain/IKON
d.porte is offline        Reply With Quote
Old 04-21-2015, 08:32 PM   #14
tisha
Default Is it that easy?
I could really use some help on a wiring diagram. I just purchased a new Ikon flybarless system to install in my blade 300x. I have a spectrum receiver with a satellite. the diagram shows using the satellite only.is that correct? if so I don't understand how to make it work with just the satalite.any help would be greatly appreciated.
tisha is offline        Reply With Quote
Old 04-22-2015, 01:57 AM   #15
jbobb1
Yes, you can use the satellite only. Set up is pretty simple.
Open the software in "demo mode" to begin with.
In the next window you chose either a full sized or micro unit if you have the newest software, which I would suggest (full size I assume in your case). Otherwise, the software will just open.
In each panel there are instructions on the left hand side. Read them closely.
DX9
Gibson Les Paul Trad Pro IV
jbobb1 is online now        Reply With Quote
Old 04-22-2015, 06:54 AM   #16
zomaar
Wire diagrams in brain software have improved. But in the pic software the gov port layout is not printed. Could this be added?
zomaar is online now        Reply With Quote
Old 04-24-2015, 10:23 AM   #17
Go for it
T-Rex 150 || Blade 180 CFX with µBrain || T-rex 250 pro DFC with Vortex Vx1p || T-Rex 450 PRO DFC || Mcpx BL || Mcpx v2 || Futaba 14SG (KDH-Modul) || DX8
Go for it is online now        Reply With Quote
Old 11-08-2015, 12:48 AM   #18
The_Norwegian
Sub'ed
Need to learn everything about heli systems, what a daunting task when you start from scratch...
DX8 & DX9 | Rakon 200 SR X | Nano CP S | Nano FPV QX | Rakon NQX (MMW CL-0615-14 Motors) | ImmersionRC Vortex | Lynx Oxy3 (Building) | Bixler 2 Long Range FPV Project | HK Rarebear War Bird Speedster Project (Goal: 150-180mph) | Misc. HK foamies
The_Norwegian is offline        Reply With Quote
Old 09-08-2016, 10:25 AM   #19
Dowquest
Default Brain2 HD wiring
Hello all,
so I'm powering my Brain2 HD with the hd power plug, and just want to confirm it is the bottom 2 contacts on the multiplex plug that the power goes thru. It appears that is the intention on the schematic, but not 100% clear.
Also, Why did MSH use a 6 contact plug for a 2 contact job?
Thanks in advance
OK, nevermind, the HD power connector pin melted when i touched it with my soldering iron... Going back thru a servo connector in port 2
Name:	brain2 wiring.jpg
Align 600N Ikon , Align 550L Brain2, Align 500 Ikon
Protos 500 Ikon
ALZRC 465 Ikon
Citizen - #202
Dowquest is offline        Reply With Quote
Old 09-08-2016, 11:41 AM   #20
etherbatxx
?? hmm, it sounds like a there is a story here that needs to be told
etherbatxx is online now        Reply With Quote
