Old 08-16-2012, 03:16 AM   #21
kimmik
Any measurement of temps? Was it at room temp no airflow?
kimmik is offline        Reply With Quote
Old 08-16-2012, 06:29 AM   #22
heliguyG6
Be nice to see the YEP 120 Along side the YGE 120
heliguyG6 is offline        Reply With Quote
Old 08-16-2012, 08:14 AM   #23
hidaven
I have an eflite 25 amp esc that id like to donate.....
hidaven is offline        Reply With Quote
Old 08-16-2012, 09:55 AM   #24
jamin_00
During these tests are you able to accurately measure exactly how many amps the Kosmik can handle at peak?
Sponsored by
Optipower
jamin_00 is offline        Reply With Quote
Old 08-16-2012, 12:51 PM   #25
Nitros83
sub
Nitros83 is offline        Reply With Quote
Old 08-16-2012, 02:27 PM   #26
Asomaro
I really appreciate the effort that you are putting into this.
Information like this is really important to try and understand especially as the size and power of electric powered airecraft is getting bigger and better all the time.
I've just put a yge 160 on my 700e and I can't wait to understand a little more about active freewheeling!
Cheers,
Simon.
Trex 550e BeastX/Trex 500 BeastX/Trex 500 Airwolf BeastX /MCPX /DX8 Phoenix & SimStick
Asomaro is offline        Reply With Quote
Old 08-17-2012, 09:18 AM   #27
ub3r
20 seconds into torture testing the ICE HV80, it failed. The test was meant to consist of pulsing the load from No-Load -> Full-load (80Amps) at 50% throttle. It looks like the capacitor leads fused out, and the resulting input voltage ripples killed the FETs.
Check out the temp rise at partial load.
The footage is taking way more time than i initially thought it would.. but trust me it'll be worth it.
Name:	ice hv80 load test.jpg
ID:	341075   Click image for larger version
ub3r is offline        Reply With Quote
Old 08-17-2012, 10:13 AM   #28
sarpilot
Well that is not good..... I have one of those on my 600
Sent from my DROID3 using Tapatalk 2
"It's not the crash so much as the sudden stop"
Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ...
sarpilot is online now        Reply With Quote
Old 08-17-2012, 10:38 AM   #29
kimmik
Pretty harsh test though. 160A motor current with 80A ripple in the caps of an 80A rated esc isn't a typical scenario. The fets would be dissipating 200W.
Old 08-17-2012, 11:52 AM   #30
rctintin
Fantastic thread, just what we need in this hobby is independent testing, not the stuff the manufactures want us to read.
It would be fantastic if you could also test the Scorpion 130 V5 as they are getting very popular. Mine has been flawless thus far in my TDR with a hand wound motor.
Henseleit TDR V-Bar
SAB Goblin 700 V-bar T-Rex 700e DFC pro HV V-Bar
Synergy N5c V-Bar YS56 T-Rex 700n V-Bar YS91 srs Futaba 18mz PL8x2
rctintin is offline        Reply With Quote
Old 08-17-2012, 01:44 PM   #31
gadawg58
I'm not real familiar with the logs yet but why do you say 160 Amp motor current. Looked like not even 80 amps or am I looking at the wrong scale? Thanks as I really don't know.
George
XXtreme 800, e Whiplash, TREX 700e V2, TREX 600 Nitro LE, TREX 600 e Pro, TREX 500, TREX 450 Pro, Raptor 90 SE, Raptor 50 V2 ... Some with duplicates
gadawg58 is offline        Reply With Quote
Old 08-17-2012, 03:33 PM   #32
Mercuriell
Does sound a harsh test but not unattainable by any means in real life in a 6 or even 700. Maybe it was the lack of AFW in the CC that caused the problem. Would it be better to try the 100% throttle load test first in case the scenario repeats!
John
Mercuriell is offline        Reply With Quote
Old 08-17-2012, 05:43 PM   #33
Elios000
there some were i can read up on what AFW is and does?
DX8
mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades
AMA#948801
Elios000 is offline        Reply With Quote
Old 08-17-2012, 09:04 PM   #34
kimmik
50% throttle means motor current is 200% of input current, and motor voltage is 50% of input voltage.
80A and 44V input at 50% throttle is thus 160A motor current at 22V motor voltage.
You will never see this situation in a 600 unless your gearing is say 5 teeth too large, in which case you will indeed blow the esc or motor in no time.
160A motor current at 50% duty cycle translates to 80A rms ripple current through the input. The two capacitors cop the majority of this current, which is why one of them fused so quickly. Can you imagine 40A flowing in each 26awg lead.
A more realistic scenario, e.g. 80A at 90% throttle:
89A motor current
40V motor voltage
3.6kW
30A rms ripple current (rms is root mean square)
15A est. per capacitor
40W total freewheeling and i2r loss.
That's why this esc in correct use doesn't fail in this mode.
Even if you have freewheel, that esc will still fail in the same mode as the ripple current is same. the esc was tested at 2x current rating and 50% throttle, no esc manufacturer ever designed for that.
To make a esc survive that scenario, you need 1. A big low esc buffer cap bank, and 2. Afw to reduce get thermal 3. Lots and lots of cooling air.
Old 08-17-2012, 10:21 PM   #35
gadawg58
Thanks for the info! Great Explanation!
George
Old 08-18-2012, 12:30 AM   #36
FireNWater
Kimmick,
So what you're saying is that this was more of an "execution" than a "torture test".
FireNWater is offline        Reply With Quote
Old 08-18-2012, 01:37 AM   #37
KU-HELI7
I agree with kimmik. 80A input at 50% throttle is far away from normal use of a 80A ESC. Especially for ESCs without AFW.
But also with AFW this is more a test, like "How fast can I kill an ESC"
In general the test is very interesting, but I would suggest to change the test procedure, other than you want to show that AFW will protect an ESC quite a time against such load, which they have not really been designed for.
But that AFW is working well, is IMHO proofed enough with all Kontronik ESCs out in the field since the Jive was introduced some years ago.
Regards, Helmut
Banshee #50 and some others ...
KU-HELI7 is offline        Reply With Quote
Old 08-18-2012, 08:57 AM   #38
ub3r
89A motor current
40V motor voltage
3.6kW
Good Post Kim.
One would expect their ESC to at handle the rated current for more than 20seconds at 50% duty. Or would they not?
Old 08-18-2012, 09:16 AM   #39
heraldo
Originally Posted by ub3r View Post
Good Post Kim.
Very true. But then again, everyone knows better than to run an ESC at 50% excluding controllers with AFW
heraldo is offline        Reply With Quote
Old 08-18-2012, 10:02 AM   #40
kimmik
Depends on your definition of rated current i think. Is it input current at 100% throttle, or motor current at all throttles, or etc etc.
I would expect my 80A castle to take 80A motor current (rather than 160A) for 20seconds at 50% throttle (ie 40A input), but i dont expect it to survive for long even at this, which was why i posted my hesitation earlier about the test.
But seems it survived for 4.5min at 40A and 50% throttle in your earlier test, which to me is amazingly impressive already.
I was happy to see 20A 50% throttle as the normal test.
