Old 08-19-2012, 09:51 AM   #61
kimmik
Very well thought through video, good stuff!
I've wondered for long time too why so few escs adopt afw. In fact when i first got into bldc motors, i assumed that they ALL used afw, because not using it is just silly.
Programming it should be easy too right? Invert the high side gate control, add delay.
kimmik is offline        Reply With Quote
Old 08-19-2012, 10:13 AM   #62
Iceberg86300
Great explanation in the video!
I was on the right track, they are just flyback loops, active gets an efficient fet, passive gets an inefficient diode.
Steve
Sent from Tapatalk using my Inspire 4g through ATT (meaning it's a wonder you can see this!)
Align T-Rex 450 pro v2 g3x FBL (in progress)
Stock except for Hyperion 35A ESC in gov mode
Futaba 7c transmitter
Hyperion 720i NET charger & RDU data logger
Iceberg86300 is online now        Reply With Quote
Old 08-19-2012, 11:06 AM   #63
ub3r
Steve
Yep. Indeed your correct.
Free-wheeling detailed explanation in this post
ub3r is offline        Reply With Quote
Old 08-19-2012, 11:08 AM   #64
KU-HELI7
Programming the AFW is quite difficult. The software makes the difference between good and bad AFW.
Regards, Hemut
Banshee #50 and some others ...
KU-HELI7 is online now        Reply With Quote
Old 08-19-2012, 11:17 AM   #65
ub3r
Regards, Hemut
Yep that's correct, its much more difficult than some might think.
Timing is critical, and if your phase runs out of residual current, you will be basically just applying brakes (by shorting the phase). This is called discontinuous mode.
The idea scenario is to measure the phase current, and when current stops flowing, you turn-OFF the free-wheeling MOSFET.
regards
Tony
Old 08-19-2012, 11:45 AM   #66
clough42
regards
Tony
Ahh...that's what I was missing. I was thinking the added efficiency of the FET would result in an opposing electromagnetic force that would brake the motor.
When the reverse EMF spike current drops and the FET switches off, what happens to the generated voltage on the coil? Does it just float? It would be the wrong polarity to conduct through the protection diode, right? Or am I confused?
Sent from my DROID RAZR using Tapatalk 2
Blade 4503D ZYX-S Tarot DFC
mCP X v2 BL HP05s/XP-7A/twin coreless
clough42 is online now        Reply With Quote
Old 08-19-2012, 11:54 AM   #67
ub3r
Your not confused. Your actually perfectly right.
The Generated voltage floats between GND and Supply, and the voltage seen on the phase is proportional to the torque ripple..
Name:	BEMF Ripple Voltages due to torque ripple.png
Old 08-19-2012, 12:07 PM   #68
KU-HELI7
Tony, somebody already asked for adding a Hobbyking YEP ESC to your test. I also think this would turn your test to a really interesting one.
Why? Especially since YGE officially stated on their homepage, that the YEP ESCs are (more or less) a 100% plagiarism of an older revision of their YGE ESC. YGE said that also the software of the ESC was stolen 1:1.
So it would be quite interesting how the YEP performs in comparison to the YGE.
Regards, Hemut
Old 08-19-2012, 12:10 PM   #69
ub3r
Hemut, I'd be more than happy to do a 1v1 comparison of the YEP vs YGE.
Just need more time as i haven't even finished these tests.
Old 08-19-2012, 12:24 PM   #70
KU-HELI7
Tony, that's only a suggestion from my side. You decide what you are doing in your test.
Regards from Austria
Helmut
Old 08-19-2012, 06:36 PM   #71
kimmik
From what I observe on the yep esc afw mode, it has either no ability to detect the end of freewheel current or an inaccurate detection, and suffers a big rpm discontinuity when going through a certain throttle.
This issue is relieved with some load eg blades.
So what esc has the best afw programming in your perspective, hemut and tony? And for what reasons?
Old 08-19-2012, 07:27 PM   #72
ub3r
So far, from what Ive seen, the KOSMIK is ahead by light years.
Even the Power-Jive struggles a little with low load.
Old 08-19-2012, 07:30 PM   #73
kimmik
If k implements the kosmik mcu in the next jive I'll be all over it
Old 08-20-2012, 12:26 AM   #74
ragge1
would you be testing the scorpion 130A ESC too
Trex 500 : Atom FBL head AR7200BX | Atom 6HV : vbar 5,3 pro | Goblin 700 : vbar 5,3 pro | Goblin 500 : vbar 5,3 pro
ragge1 is offline        Reply With Quote
Old 08-20-2012, 01:31 AM   #75
KU-HELI7
I also would say that Kontronik has the best AFW. Also Gov and smooth spool-up is the best.
Because of that the Jive is well established on the market since years. The Jive is an absolute carefree package.
The Kosmik is new on the market. So we have to wait, until more users got their hands on it. The Kosmik has an extreme smooth spool-up. It looks like a real heli. So this feature is very nice for big electric scale helis.
The Kosmik is quite big and strong. I would say, the Kosmik is too big and not necessary for a 700 heli.
I will use a Helijive with a 4530 for my Banshee. With good cooling the Jive can handle peaks about 240A without problems.
Regards, Helmut
Old 08-20-2012, 01:57 AM   #76
aziz76
This thread is really enlightening... Well done ub3r on the clear and concise explanations, and an excellent test!
A\ziz
"The worst form of inequality is trying to make unequal things equal." Aristotle.
aziz76 is offline        Reply With Quote
Old 08-21-2012, 02:07 AM   #77
Elios000
awesome thanks for the post on AFW you didnt need to go that far a link to a wiki or some thing would of been fine
DX8
mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades
AMA#948801
Elios000 is offline        Reply With Quote
Old 08-21-2012, 02:47 AM   #78
CyprusFlyer
Thanks Ub3r, my line of work is electronics too, not a clue about ESC specifics though, so very enlightning for me too and appreciate the effort.
Assume you are the same guy that looked into CC problems a while ago and impressed Patrick: http://www.rcgroups.com/forums/showt...1450849&page=7
Great to have a real independant authority on ESC's although pretty well hooked on Kontronic, shame about the costs though, but for piece of mind .
Great to understand the theory though and testing though.
TREX 550E
LOGO 500SE & 600SE & 600SX
Synergy E7
zzzzzzzzzzzzzzTDR
CyprusFlyer is offline        Reply With Quote
Old 08-21-2012, 06:03 AM   #79
Mercuriell
Discussion on AFW in YGE clone moved to Electronics Forum here
John
Mercuriell is online now        Reply With Quote
Old 08-23-2012, 11:33 PM   #80
kimmik
Hey tony if you get a chance, i'd like to nominate pwm as your next point of discussion. I'm interested in a detailed breakdown and estimate of the pwm esc losses and pwm motor losses.
In particular the effect of fet drain source charge, voltage, current, switching frequency, afw on the switching losses. Would be nice to have a general idea of how much total loss it is.
