Old 11-15-2012, 09:54 PM   #61
Tim@AssuranceRc
Originally Posted by sarah1097 View Post
This is the reason I went with Sab instead of align. I really wanted the new dfc 700 but align's customer support is below failing. Speaking w Tim from assurance is pointless since he never cares. I tried calling at least 10 times on a different issue and he was never there nor would he call back. In addition I had a problem w some parts on my Sab goblin and they just sent me the parts. With Tim he makes you send the parts receipt and then if then you may get them at cost. Not to mention it takes him 6 weeks to do anything. I am normally not this critical but align as all but lost my trust and business. I have never spoken to Jeff so I can comment because that would be unprofessional but I feel bad for all those who have been loyal to align and they get no service of barely any at all. The sad part is that I still really enjoy my align helicopters that I have. (Specially my 700 f3c)
Hello Sarah
I apologize if I did not get back to you in a timely manner but I have never talked to you, nor did you call. I have only spoken to your "brother". My sales staff is really good at giving me messages for customer calls I may have missed.
I strive to provide excellent service. My usual turn time for RMA items is 2-4 days. You may also feel free to email me at tim@alignrcusa.com
Tim T.
Align USA
562-598-4700 x10
tim@alignrcusa.com
Align USA
3626 Briggeman Dr
Los Alamitos CA 90720
562-598-4700 x10
Tim@AssuranceRc is offline        Reply With Quote
Old 11-15-2012, 10:31 PM   #62
sarah1097
Location: From Utah, transferred from u of u to u of washington
Dear Tim
I disagree with your response but will pm you and email or call you. I am sorry for posting your name in a forum it is /was unprofessional.
Sarah
sarah1097 is offline        Reply With Quote
Old 11-16-2012, 07:59 AM   #63
Dino Spadaccini
guys i was contacted by the factory and a solutions is being worked on at the moment i feel that you will all like what Align will come up with
Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote
Old 11-16-2012, 08:04 AM   #64
msallua
Dino
Thanks for the feedback
I have no vibration problems in this moment.
What is the recommendation of the factory?
Will our birds should be grounded?
Sab Goblin 700 Yellow // Align 700 DFC HV. BeastX :// Align 550 V2 DFC. BeastX // Align 450 Pro V2 DFC . BeastX // Futaba 10Chg - Phoenix RC
msallua is offline        Reply With Quote
Old 11-17-2012, 06:52 PM   #65
Nicasiobantolino
Default affraid to fly a very expensive model
ok i have flown my dfc 3 times first off i have had a 3gx reset that demolished my first 700v2 and when i called assurance i was given some rediculous discount i found a kit for cheaper than they quoted me at another dealer so when i got my dfc that was the first to go i got a vbar my first flight i had alot of vibes tore it down rebuilt it sanded the main shaft shim flew again still alot of vibes so i put the kde pitch slider links no change now im affraid of the tail snapping off i hope this happens quick im ready to put this thing on ebay for best offer and get a logo 700
Nicasiobantolino is offline        Reply With Quote
Old 11-17-2012, 07:29 PM   #66
Dino Spadaccini
Put a set of non align tails on like edge and test hover you should be fine
Old 11-18-2012, 09:42 AM   #67
chosen69
Check this out.
Trex 600EFLpro
Trex 600NSP DFC
Goblin 700
chosen69 is online now        Reply With Quote
Old 11-18-2012, 09:48 AM   #68
Dino Spadaccini
Default the fix for the tail
Old 11-18-2012, 09:48 AM   #69
treotraveler
Originally Posted by chosen69 View Post
Check this out.
Already a thread on it here....
http://www.helifreak.com/showthread.php?t=472299
Trex 500esp fbl dfc 6s
Trex 600cf fbl 5 blade Hughs 530f TT 6s x2
Trex 600efl Pro fbl 12s Trex 700e v2 12s
Chaos 600e fbl 4 blade Blackhawk 12s Chaos 600e fbl Airwolf 12s BeastX DX8 DX18QQ TX
treotraveler is offline        Reply With Quote
Old 11-18-2012, 09:49 AM   #70
Dino Spadaccini
Old 11-18-2012, 11:49 AM   #71
K2Freak
I run the older stuff, but can someone explain how changing the TT gears will stop the tail shafts from breaking? Do these gears reduce vibration? Do they somehow mitigate the effects of the too heavy tail blades? Am I confusing more than one issue here? Don't get me wrong, they look nice.
And I'm not trolling! I am very curious!
T-Rex 800E CHP DL / VBar / YGE 160HV / X-era 4030 470kv / MKS DS660A+ & DS760 / Align 780mm / Gryphon Quasar / KDE performance tail
K2Freak is offline        Reply With Quote
Old 11-18-2012, 05:17 PM   #72
Helos4me
Add one more. It occurred in a vertical pirouette, after I had put it through some left right spins at altitude so I would have plenty of time to auto in. 10+ flights. Personally I believe it's a weak shaft. Now I'm also down 3 servos.
700e DFC / KDE 700XF-495 and mount
CC Ice2 HV120 / BEC Pro
Sk 720 Flybarless / Batt Bus
Helos4me is offline        Reply With Quote
Old 11-18-2012, 06:02 PM   #73
Helos4me
One, has anyone tried the 700N shaft with any success?
Two, all three servos are locked up. Any chance they are salvageable?
Old 11-18-2012, 06:22 PM   #74
Steemo
what happens when you power them up?
I've had some servos in the past that won't move by hand but worked great under power and radio control.
just be ready to unplug the power in case they are really seized, you would just need to replace the gears in that case.
T-Rex 700E DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro | T-Rex 500 DFC Pro AR7200BX
JR DSX9 LE Mode 2
Steemo is offline        Reply With Quote
Old 11-18-2012, 07:33 PM   #75
Helos4me
two of them move under power, one doesn't. Prior to all this they could be back driven very easily.
Old 11-18-2012, 08:03 PM   #76
rando
Nice demonstration of how insanely strong the new TT gears are ... but how does this mitigate the snapped shafts?
700E DFC HC3sX//Logo 600SX VBar//Logo 600SX Mini VBar//550E DFC HC3sX
rando is online now        Reply With Quote
Old 11-18-2012, 10:58 PM   #77
Steemo
I'd probably use the 2 if they run smoothly and center well, maybe just open the casing and inspect the gears, clean out the lot and re-grease, while you are cleaning you would probably notice and missing teeth or imperfections. When in doubt don't risk your $2k model on a $30 servo gear set. for the other that doesn't turn inspect the gears on that too but I'd bet money on you needing to replace the gears.
JR DSX9 LE Mode 2
Old 11-18-2012, 11:44 PM   #78
AbdulBasit
Hi,
What has happened to you happened to & lost my landing gear, side frame, one battery pack, main blads... I wish to know what could be the problem. .. Align should be careful not to spoil the brand personally love Align & it the best among what I have, for more then 7 years without problems as such ....
Sent from my GT-N7100 using Tapatalk 2
AbdulBasit is offline        Reply With Quote
Old 11-19-2012, 05:34 AM   #79
bestan
i dont think this is a fix for the tail problem of the trex700 dfc
listen: like we said we need dampening at the tailrotor. copy the logo700 tail and we will be happy
we neither want a step down on the tail shaft. there is no radius on that - makes it more likely to break
how many people have allready crashed their heli paied lots of money for this monkey design
including someone could get hurt or even killed
so bring a 6 mm shaft with a 6 mm tail hub and plasic tail blade holder with some slope or a design with dampening built in like the logo 700
AND if align in future has a problem with some design just come here and ask for solution because here we are professional engineers that know what they do
happy landings
bestan is offline        Reply With Quote
Old 11-19-2012, 05:59 AM   #80
Dino Spadaccini
guys i jumped the gun with the tail gears as part the of fix, I just received and email from Align and they have a solution for the hum. Sorry for getting ahead of myself on this matter but the Fix will happen and i will update everyone as soon as i know
