Go Back   HeliFreak > R/C Electronics Support > Hitec Radios > Hitec Gyro/Servos
Hitec Gyro/Servos Hitec Gyro and Servo Support
Old 08-18-2012, 05:16 PM   #1
varacer
Default 5245mg problem
Ok my 500 tipped over and now I have 2 5245mg servos that seem to work fine under power but when not under power the servos will only turn in 1 direction and not the other way and will only go back the other way when battery is turned on. Ive checked the gears and are fine. Anybody have a solution?
varacer is offline        Reply With Quote
Old 09-05-2012, 05:44 AM   #2
wanderer56
You definately have something wrong inside. Take them apart again and check the pin support hole on the outer cover. They will often break and cause resistance in rotation of the gears.
Also try loosening up the outer case screws. Sometimes overtightening them can cause binding on the gears.
BTW my 5245's are not very easy to move when un-powered also.
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC
Trex 450 Sport-450M, 13T, RCE-BL35X, HS-5065MG, HSG-5084MG, DS760
DX8
wanderer56 is offline        Reply With Quote
