Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 08-23-2012, 09:32 AM   #1
Adam F
Default X50 tail rod ???
I would like to mount my Tail servo on the tail , I have the bracket for the servo but don't now what rod (length) o buy and where to get it ?
Any advice is greatly appreciated
Adam F is offline        Reply With Quote
Old 08-24-2012, 01:12 AM   #2
x50B
I believe the x50e has the tail servo mounted on the boom, the part number for the control rod is PV1424 and the length is 580mm + the Ball links.
MSH Prôtos 500 FBL: HC3-SX, Futaba 9650, Futaba BLS 251
Titan x50B FBL: HC3-SX, Savöx SC-1258TG, Futaba BLS 254, Futaba GY701, RL.53, Rail 606's.
x50B is offline        Reply With Quote
Old 08-25-2012, 07:29 AM   #3
KouDy
Default setup is that tail servo is all the way in the front. Maybe you could split the long linkage (it would mean not assemble it actually) and mount servo where the link ends.
Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
Old 08-27-2012, 01:05 PM   #4
Adam F
Thanks for the help guys , I will check the par number and see if that's what I am looking for . One the other hand you cant use the rod it's set with because is only threaded on one end and airs a bit to short
Old 08-28-2012, 06:52 AM   #5
darryl123
use the stock connector and shorten the stock rods to the length that you need
raptor 90 fbl
raptor 50
raptor x50 fbl
raptor e620 fbl
darryl123 is offline        Reply With Quote
Old 09-14-2012, 10:26 AM   #6
texasclouds
or make one out of carbon fiber tube and insert x" of threaded rod in each end for micro adjustments.
texasclouds is offline        Reply With Quote
Old 09-14-2012, 03:01 PM   #7
Elgyn
solder one of these on so you can thread on a ball link
http://www3.towerhobbies.com/cgi-bin...?&I=LXD893&P=0
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP
Elgyn is offline        Reply With Quote
Old 11-05-2012, 05:09 PM   #8
Voma
Default Tail set up
Mine sheared in half. totalled heli. I since have a new airframe and used the Trex 600 carbon tail boom servo mount and carbon tail rod and guide. It works perfect and i dont have to worry about the piece of crap X50 tail rod. You will have to cut the rod down a little but thats no big deal
Voma is offline        Reply With Quote
Old 11-07-2012, 12:32 AM   #9
esmoglo
Do you have a photo of it? I may do the same mine has not give me any issues but I want something better. Don’t the sell a carbon tail servo bracket for the X50? I recall they had one for the Raptors and Heliproz sold them….Anyone on this?
Angelo
esmoglo is offline        Reply With Quote
Old 11-18-2012, 06:50 AM   #10
esmoglo
Hello? Wow its quite slow over here guess the Titan is not really what one would call a hot heli...too bad because it fly's way better than any T600 that I have ever flown..
Anyone know if this will work on the Titan?
http://www.heliproz.com/MPV0321-Carb...ctinfo/804490/
Angelo
Old 11-18-2012, 10:08 AM   #11
KouDy
I didn't test it myself but here you can see it's obviously mounted using something similar (if not the same).
Old 11-18-2012, 12:08 PM   #12
esmoglo
Cool looks like it just might fit then
Angelo
