Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Titan X50E
Titan X50E Thunder Tiger Titan X50E Helicopters
Old 08-27-2012, 09:26 AM   #1
daveiga2005
Default titan x50e need info
need pics of some wireing im running beastx and with it in the back my servos don't reach and is there any other place were i can put the beastx.im using all servos and ecs,motor from a trex 600 efl thanks for any info
daveiga2005 is online now        Reply With Quote
Old 08-27-2012, 10:55 AM   #2
charliejjr
I mounted mine in the back and you will need a couple of servo extensions to reach it.
My son mounted his up front on the side of the frame and I believe he had to use a couple of servo extensions also. Here's a couple of pictures. Hope this helps you out.
Charlie
Name:	x50 012[1].JPG
ID:	343976   Click image for larger version
Name:	x50 013[1].JPG
ID:	343977   Click image for larger version
charliejjr is offline        Reply With Quote
Old 08-27-2012, 01:16 PM   #3
daveiga2005
thank. how do you like the x50.im coming from the trex600 efl.and aare you runing 12s.and wats a good headspeed for this heli doing mild 3d.thanks again for the pics
Old 08-28-2012, 11:27 AM   #4
charliejjr
See this thread. I posted my setup there.
http://helifreak.com/showthread.php?t=426433
Charlie
Old 08-28-2012, 04:06 PM   #5
daveiga2005
i think im going to mount it on the side.and i checked out your post thanks
Old 08-28-2012, 04:11 PM   #6
raptorz499
I mounted mine right on the front tray laying flat as close to the servos as possible...works great.
raptorz499 is offline        Reply With Quote
Old 08-28-2012, 06:38 PM   #7
daveiga2005
raporz499 i was thinking the same thing.are you running a beastx?and how is the tail holding being that far from the main shaft.
Old 08-28-2012, 08:18 PM   #8
raptorz499
Solid as a rock bud! I can send you a picture if you like? I have the esc sideways in the front tray and the lipo forvthe electronics where the esc "should be"
Pm me your email address and I can send picture
Old 08-29-2012, 07:40 AM   #9
daveiga2005
Pm sent.I'm using the Bec pro that's connects to one of my 6s lipo.I'm running the tp 3850 65c x2 i think it saves a little weight.this is the set up i was running on the trex600 efl I'll post pics when I'm done with the build.thanks to everybody that posted to help me out heli freak #1 can't wait to get it up and going.now i need to know watt its a good headspeed for doing mild 3d thanks again everybody for the help
