| Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters |
hi guys,
i was out flying my embla 450 fbl heli and when i landed i noticed the motor was very hot. i forgot to take my temp gun to see what it was. but anyway anybody els useing the stock embla motor?? does your motor run hot ?? |
i think im going to get a scorpion motor but not sure witch one to get ?? im going to stick with 3s batterys.
I'm using a Scorpion 2221-8 (3595kv) and a 14T pinion with a Kontronik Koby 40.
Awesome!
Henseleit TDR; Alees Rush 750; Synergy E7; Miniature Aircraft Whiplash; Compass 7HV; Hirobo EMBLA. Fabio To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
i'm using the stock motor with stock pinion gear and the motor does get hot. i have flown my fbl embla 30flights now and the stock set up is working nicely. i'm planning on going 6s but i would get the scorpion -8 motor for it if i were to change the motor
#5 | |
ya i was a little worryed about the stock motor getting hot but it seems to be doing good. so for now im going to use it but im also going with a 6s setup on this bird sould really wake it up. all i have to get is the motor ( i want the hyperion 6s motor ) and need some 6s 1300ma batterys. allready have a cc ice50 esc that will work great with 6s setup. |
#6 |
I am running the kontronik Kira and koby 55 in my embla. I will check which pinion I have in as I did change from stock. Work real nice for me. Spirt flying 7 minutes on a 2600mah gens ace or Hyperion and I am only down to 28%. FBL embla.
Sent from my iPad using Tapatalk HD |
