Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Titan X50E
Titan X50E Thunder Tiger Titan X50E Helicopters
Old 08-29-2012, 11:01 AM   #1
daveiga2005
Default who is running 12s
I want to run 12s.i would like to try running the gov on the icehv 80.watt pinion are you running i watt the get 1900 2100 2300 in my flight modes.thanks for any input
daveiga2005 is online now        Reply With Quote
Old 08-30-2012, 02:14 PM   #2
dhawks
I'm running 12s with the 15T pinion, but I'm using 500KV motor. I'm using the ICE2 HV80 speed controller in gov mode.
Dennis
dhawks is offline        Reply With Quote
Old 08-31-2012, 07:07 AM   #3
daveiga2005
I never used a gov before.will the headspeed be to high with out the gov.I'm going to take it for its first flight after work I'll be running a low headspeed till i decide if I want to use the gov.watt headspeed are you running in gov.thanks for any input to this
Old 09-06-2012, 03:09 PM   #4
dhawks
2100 according to the calculator,but I've never put a tach on it.
Old 10-06-2012, 09:37 PM   #5
ghenders
I am using a 700mx 510kv on 12s and a Ice2 120hv ESC. I am using the gov function with RPM's set a IU1- 2000rpm and IU2-2175rpm. Per the calculator in the castle creations link software, 2200rpm has too little headroom utilizing the stock 15-tooth pinion. To be honest, at 2000rpm this heli flies very nice with very authoritative pitch pumps. I really don't see a need to mess with the pinion at this point.
ghenders is offline        Reply With Quote
Old 10-17-2012, 10:03 AM   #6
raiden83
Im using it with 2x2650 pack in serial and align 600mx 510kv with ice80hv. Performance is good for me im not 3d pilot
- Velocity 50 n1 - (coming soon) / OS 55 / Align 50 Muffler / Align 3GX / Align 3G Blades / Futaba 7C
- HK 450Pro v2 FBL
Trex 500ESP - SOLD
Trex 600NSP - SOLD
raiden83 is offline        Reply With Quote
Old 10-17-2012, 11:55 AM   #7
DavidTan
Default 12S
Im running 12s1P with Quantum 560KV motor and 13 tooth. HS is about 2100 at 85% for phase sensor governor. Batteries are warm not hot with consistent power thru 3-4 mins.
DavidTan is offline        Reply With Quote
