| Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
I would like to calibrate my 14MZ, but I can not find the calibration program in this thread. Can somebody show it to me where to get it ?
Thanks a lot |
You can find the FX40 one on RCFAN page:
http://www.rcfan.com/radios.html It will work on certain condition with the 14MZ. I have just recalibrated my sticks with it because of neutral points that were off. |
Just make sure that when you use this FX40 version you also need to go back to encoder version 1.31.
I learned this the hard way
***** If it FLIES it WILL CRA$H ***** T18MZ, JR Sylphide E12 & 90, JR Airskipper 50 FBL, Hirobo Sceadu EX 50, Hirobo Lepton EX |
#4 | |
does it depend on the installed firmware in the t14?
It is not too late never to live a happy infancy! |
Yes.
I had to use the encoder 1.31 software in the 14mz to get the utility working. Greetz, Marc
#6 | |
With 1.31 firmware, it perfectly works...
#7 |
The LST,RST,LS,RS no in the Calibration Program ,it invalidation ?
#8 |
Anyone know what functionality the different buttons in the lower right corner with something that looks like japanese or chinese characters (or similar) is providing?
Would be nice if someone could "translate". |
#9 |
Hi oak,
I don't recall these, could you take a picture? |
#10 |
When you go into "calibration", and the press "compensation" to start the calibration process, five buttons appear in the lower right corner of the screen. Let's name them button 1 to 5 counting from left to right. (see attachment 1).
- Pressing button 1 OR 2 toggles the appearance of button 2 (see picture 1 vs. 2). - Pressing button 3 toggles the appearance of itself (see picture 2 vs.3). - Pressing button 4 brings up a window with three tabs as shown in picture 4 through 6. - Pressing button 5 brings up a window with two tabs as shown in picture 7 and 8. |
#11 |
This is the Input Method Editor (IME) from Microsoft to choose between the different writting style in Japanese (picture 1 to 3). Then you have the property screen where first tab is the imput system (picture 4), the second is the dictionnary used (picture 5) and the third is the version information (picture 6).
The last two picture are about customizing the dictionnary. The first tab (picture 7) allows you to add a new word and the second tab (picture 8) to remove some. I don't know why it is there. This input editor function normaly appears when you have something to write in a form for example. |
#12 |
Thanks, that clarified things a bit.
#13 |
Can someone PLS mail me the 14Mz Clabration Software and the Utility
guruduttdhuri@yahoo.co.in Regards, Gurudutt. |
#14 |
do a virus scan first before using. i will not be hield resposible if you brick your 14mz.
use at your own risk!!! this is the version 1.31 encoder http://mywebpages.comcast.net/tranth...4MZ_V1_3_1.zip this is the t14mzutility software http://mywebpages.comcast.net/tranth...st_program.zip this is the pdf format instruction manual http://mywebpages.comcast.net/tranth...1M23N14837.pdf you must downgrade the encoder to 1.31 to run the utility. use the utility to calibrate the transmitter sticks only, dont calibrate the switches. this utility is for fx-40 and switch mapping is different from 14mz. after the sticks are calibrated, you can upgrade the encoder to the latest version again. also make sure you back up all your models stored on your transmitter onto the memory card for safety. reply back to this thread if you have sucessfully calibrated your transmitter with the above programs.
Tam |
#15 |
Who can help me?i want only change mode from 2 to mode 1...but i have a problem...i use a memory card to downgrade at versione 1.3.1 and its ok
when i put the t14mz utility program, it start but when arrive at choose menů it stop and i read model save data and its shutoff. in update mode its don't work... who can help me please...where i wrong? |
#16 |
who help me???
pleaseeeeee!!! |
#17 | |
#18 |
ok...i don't have any problem i use firmware 1.0.1 and it work very good...
now i have my t14 mode 1 and all stick recalibrated...^_^ Very very simple... i don't spend money ^_^ |
#19 |
Hello, I have the same problem with firmware 1.3.1
It turn off immediatly after turned on. Where can I find the 1.0.1 firmware please ? |
#20 |
this is the updated manual of the calibrated utility. the above link is now null.
http://home.comcast.net/~tranthienta...thout%20OS.pdf
Tam |
