Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 09-03-2012, 05:41 PM   #1
geoffh
Default X50F tail control rod broke in flight
Hello, I have ran 1.5 gals through my X50f and today the tail control rod broke in flight. I some how was able to recover and land with no damage. It broke in the middle of the bend radius at the front bend. I have verified the alignment and travel to check for binding and could not find a mechanical cause for this to break. I did a search and saw some mention of tail rods breaking when the X50's where first coming out. Is this the same location the previous rod issues where? Has the been any new development or replacment parts developed to solve the problem?
geoffh is offline        Reply With Quote
Old 09-03-2012, 08:03 PM   #2
johnbs8
put shrink wrap on the bend. 2 pieces. this is what the team pilots were doing. i cracked one at ircha this year. luckily i saved it. when i talked to them that was what they do and i inspected their machines.
Titan X50B : YS56sr GP Pipe, Tracx600 FBL, AR7200BX, Ds610 X4, DS650, Pushglo and compass 615mm FBL
Titan X50T : Ys56sr SAB-55 Pipe, Tracx600 FBL, AR7200BX, DS8717 X3, BLS251, Pushglo Radix V2 625mm FBL
johnbs8 is offline        Reply With Quote
Old 09-06-2012, 09:34 AM   #3
esmoglo
Any photos?
Angelo
esmoglo is online now        Reply With Quote
Old 09-06-2012, 07:01 PM   #4
geoffh
Here is a pic of the break.
Name:	x50 broke tail rod.jpg
Old 09-14-2012, 10:28 AM   #5
texasclouds
nice save. i don't like the looks of a bent pushrod on a heli tail (personal preference).
how would shrink wrap help? i don't see any structural advantage.
texasclouds is offline        Reply With Quote
Old 09-14-2012, 03:03 PM   #6
Elgyn
I would keep it together long enough to get on the ground
TT titan x50 / TT mini titan / JR Vigor CV... ...vbar'd / 700 airwolf streched JR Voyager mechanics / JR Venture CP
Elgyn is offline        Reply With Quote
Old 09-19-2012, 08:12 PM   #7
YBNORMAL
I did this to my X50 the other day. Wiped the rod down with alcohol and put on a length of 1/8in shrink so that it covered both bends with room to spare. Then I put a slightly shorter length of 3/16 shrink over that just for added strength. I figured the added security against unexpected piros was worth the extra weight.
YB
Titan X50TT, YS56, GY701
Trex 250 pro all stock.
Trex 450DFC 3GX Pro all stock.
DX8
YBNORMAL is offline        Reply With Quote
Old 09-19-2012, 09:25 PM   #8
Rob43
I've yet to figure out why they use this design. The machine is so excellent otherwise. Anyone tried another solution?
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 09-22-2012, 07:23 PM   #9
YBNORMAL
There was a picture I have seen floating around where a guy installed an Align style see saw link right about where the boom goes into the boom clamp.
Not sure where I saw it though.
YB
DX8
Old 09-25-2012, 02:29 PM   #10
Elgyn
I agree
tail mount from the X50E? Although these are tail heavy enough.
Old 09-25-2012, 03:01 PM   #11
tr911
Why not move the servo to the boom like the R50 Titan SE?
Titan x50 FBL, R50 Titan SE FBL, R50 V2, R30 V2 , Trex500, T-Rex 450x2, mCPx X2,
tr911 is offline        Reply With Quote
Old 09-26-2012, 10:21 AM   #12
Adam F
That's what i did . I had a carbon tail servo bracket from my old raptor that had a crash . I installed it and so far it is working out great . That's my best suggestion.
Adam F is offline        Reply With Quote
Old 10-20-2012, 02:48 PM   #13
Davenportc
Hi,
I'm building my new X50 now. Has anyone considered putting a couple small trianges of balsa at the bends for strength? I was thinking about doing this after reading this thread.
Chris
Davenportc is offline        Reply With Quote
Old 10-21-2012, 03:36 PM   #14
YBNORMAL
Originally Posted by Davenportc View Post
Hi,
Chris
It is worth a shot........I don't have many hours on mine and have not had the rod fail on me. Iike I posted above I used the shrink tube mod in case it would break. My gut tells me this is a vibration/stress fracture type of problem.
I am using a JR MP80G servo on the tail and it is very fast and known to buzz a little when stopping back at center. So I installed a length of fuel line on the straight stretch of control rod, closest to the servo and zip tied one end of the fuel line. My hope is that the fuel line acts as a damper for the vibrations, The servo buzzing stopped after the rubber fuel line was installed.
YB
DX8
Old 10-30-2012, 08:22 AM   #15
Ickleroc
After having issues with my tail, as a last ditch I tried one of the Raptor tail boom mount kits from Quick UK. Instant success, Okay it moves the CofG back a little but a little weight upfront (or bigger Rx pack ) sorts that.
I Prefer the slightly heavier heli with a tail i can trust to fly and not break mid flight, or wag like a puppys tail.
http://www.quickuk.eu/products/169/t...kit_rt-24.html
Ickleroc is offline        Reply With Quote
Old 11-05-2012, 05:03 PM   #16
Voma
Default broken tail rod
My tail rod broke in half around the middle of the boom on my X50, resulting in a complete totall. Just sheared in half during flight. I got another airframe and i mounted my servo to the tail boom and used the Trex 600 carbon tail rod and guide. Problem solved. Alot of these rods are breaking and its bullcrap
JOHN
Voma is offline        Reply With Quote
Old 03-07-2013, 03:27 PM   #17
KnoxHeli
I purchased the Align 600 carbon/dual clamp tail boom bracket and am going to use a fiber rod, however can't seem to find a tail rod guide (Align 600E). Does anyone know a P/N?
TT Titan X50F w/ TT .53 and AR7200BX
Align 600N w/ Hyper 50 and GY611
Align 450 PRO DFC w/Scorpion -8, 50 LITE and DS95s
Blade 130X and Spektrum DX-8
KnoxHeli is offline        Reply With Quote
Old 03-07-2013, 04:46 PM   #18
tr911
If it were me I'd go to the hobby shop and get a piece of hollow fiber rod and make my own.
I guess that is what you are asking..
Old 03-07-2013, 08:20 PM   #19
KnoxHeli
Something like this, that I think goes on a TREX 700? Not sure if boom diameter is the same?
Name:	tail guide.jpg
Old 03-07-2013, 08:53 PM   #20
tr911
Got it, I haven't seen one for a x50. I have made a control rod for one of my R50's and didn't use a guide. The fiber rod I used was 4mm if I remember correctly, stiff enough that I didn't need a guide. This one may work..
http://www.heliproz.com/PV1377-Rod-G...ctinfo/PV1377/
