Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 09-07-2012, 03:19 PM   #1
sp00fman
Smile Fixed tail vibration
I have just (hopefully) fixed a pretty severe tail vibration on a new build plastic 425.
Everything is smooth until i hit 2500rpm. When I increase head-speed even more it gets much worse, the tip of the vertical fin vibrating sideways about 3cm and i got worried it would hit the tail blades at some point.
Things i changed, but got similar results:
-new tailshaft
-put on the X5 tail hub+grips
-back to stock tail blades (tried with the 550 tail-blades first)
-adding different lengths of tape to one tail blade to see if things get better
The thing that fixed it was just tightening up the belt. This does increase friction somewhat, and it stops a bit sooner when spinning the head (without blades) by hand.
Thinking about why this would fix it, i came to the conclusion that the belt is giving tension on the tail shaft, tightening it on the bearings a little.
Sure enough after inspection i found wear marks of the tail shaft rotating in the bearing inner race.
Grabbed a new set of bearings ( to be sure) and glued the inner race on the shaft with anaerobic retainer.
Tail spins up free of vibrations, even with a pretty loose tail belt. It even rattles in the boom a moment when spooling up, but stops soon. I suppose that is all right.
Just want to share my experience. Was about ready to give up and ask for help here.
Glue your tail bearings guys
FBL clone 250 + 450's - with CX-3X1000
FBL GAUI Hurricane 425 EP with ZYX-s -=- GAUI Hurricane 520mm - bell/hiller mixed paddled stabilization
The more money you have up in the air, the less you love it...
sp00fman is offline        Reply With Quote
Old 09-07-2012, 03:40 PM   #2
PTcaflyer
...I had that too with a stock tail case and X5 grips...shook so bad it threw the link pins out of the slider...case was cracked...Put an X5 case with new Brgs and run the 550 tail blades...SMOOTH AS BUTTER!
Gaui 500 / Tarot Quad 450 KK2.0LCD/ X525 (2X) DC 450 FPV 500mw 5.8 / SC10
AMA 953414
PTcaflyer is offline        Reply With Quote
Old 09-08-2012, 12:35 AM   #3
Jerrymac
Hmmmm, I am having the exact same problem with a fairly new build that has less than a dozen flights on it. The vertical fin vibrates so bad it looks like it is going to break off. It did this right from the maiden flight though.
I was thinking maybe my main blades are not balanced perfectly, but I guess I will give the tail a look over too.
I don't need the latest and greatest. I just need more time to fly what I have.
Helipro 450se, Gaui 200, Gaui 425 x 2, Gaui "HeadHunter 500, Gaui 550
Jerrymac is offline        Reply With Quote
Old 09-08-2012, 10:10 AM   #4
PTcaflyer
Yep...check it closely...it appeared o.k. until I twisted it and the crack opened up...the faster it spun, the more torque would twist it...I made a G-10 "stiffener" for my CF Vert. Tail and now it wouldnt flutter even if I tried.
PT
AMA 953414
Old 09-08-2012, 01:17 PM   #5
minititinflyer
i had the same problem for a bit but i got new tail blades kbdd 70mm .and checked over my links to see if there where tight sized them. and put some grease on the dampers and it stoped for me. i also found the oneway bearing comes dry as a bone in a new kit poped some stuff in there and its smooth as ever
blade msr!, blade mcpx! ,blade 130x!, trex 250!, ,mini titan e325 v2! ,gaui hurricane 425e! ,trex 600 esp!, trex 700e! ,Hitec Aurora 9!, spektrum dx6i!
(Mr.heli)
minititinflyer is offline        Reply With Quote
Old 09-08-2012, 07:37 PM   #6
blade_crasher
Speaking of lubrication of the OWB. What is the correct stuff for that? Is aerosol silicon ok, or light "sewing machine" oil, or something more like silicon grease?
I got some of my 550 parts and put the new tail boom on. The boom support rods that go down to the bottom of the rear landing gear now seem sort of "short". Do I need to extend these rods by replacing the aluminum with a longer part or some type of CF rod mod?
blade_crasher is offline        Reply With Quote
Old 09-08-2012, 08:25 PM   #7
PTcaflyer
OWB needs to be almost "DRY"...light oil or a drop of ATF, then swab it like your gun barrel(oops! wrong forum!) I use Scorpion oil too...
The boom supports are all the same length( I Think..) but the X5 supports area little longer...I use the stockers on all of mine...
AMA 953414
Old 09-08-2012, 10:46 PM   #8
Jerrymac
Don't over lubricate the OWB as it may cause problems. I have read of many failures on here, although I don't know for sure what caused them. I put a couple of drops of ATF on my OWB's during assembly. So far, 4 years and 4 different Hurricanes and I have yet to experience a OWB failure.
Also, during assembly, DO NOT put 2 washers on the OW shaft. Put only one washer below the OWB. I think many of the OWB failures were caused by the top washer wearing and the tiny metal bits dropping into the OWB. (Just my opinion, not sure why so many people reported OWB failures).
Tail boom supports are the same for the 425/550. Just move the part on the boom closer to the frame until they fit.
Old 09-09-2012, 04:26 AM   #9
sp00fman
My OWB did come lubed, so i left it alone.
Other things i noticed on this newer kit are that the tailshaft pulley can move a tiny amount sideways in the plastic tail assembly. I placed a thin washer between it and now the tailshaft bearings are slightly pre-loaded. This makes it less sloppy.
Other things i noticed is the canopy mounts are a new style, the tail grips are held by a locknut instead of a screw. Did find one small problem on the main head. I needed to flip the featheringshaft screw spacer for high damper compression to take the slop out of the main grips.
Otherwise a really smooth build, except the tail bit
One thing i need to keep an eye on is the auto-rotation assembly heating up. it feels quite hot when i feel it after a 5 min flight.
Will take some measurements soon.
Old 09-09-2012, 10:35 AM   #10
minititinflyer
look for one way bearing grease its the best stuff to use no oils. it dosent gum too. bc i use it on all my helis and there smooth as ever.
(Mr.heli)
Old 09-10-2012, 06:15 AM   #11
sp00fman
Hot drivetrain is solved with a little WD40 on the main and front gear. Gears are 10°C above ambient, batteries and motor 15°C after 5 minutes sports flying.
Old 10-13-2012, 11:03 AM   #12
tolenca
Hi, may I ask you what "anaerobic retainer" did you use? I have that vibration after 2400 rpm
Thanks in advance.
tolenca is offline        Reply With Quote
Old 10-13-2012, 03:42 PM   #13
sp00fman
I dont think brand name matters much. many just call it green loctite.
This is the one i have. I really hate/love it. The stuff is EVIL. Only applying heat will get get my bearings off the shaft again.
Old 10-13-2012, 10:02 PM   #14
tolenca
Thank you.
Later
Old 10-14-2012, 07:09 AM   #15
sp00fman
Oh, my bad. this is the actual one i got for this use.
http://www.hobbyking.com/hobbyking/s...Strength_.html
pm send
Old 10-14-2012, 04:13 PM   #16
tolenca
ok..thank you again
Old 10-21-2012, 02:34 PM   #17
sp00fman
Got all bugs out of the heli and it is flying really well.
Got my first real flights in, pushing it a little more. I'm still taking it easy, not used to this size heli yet. Adrenaline was pumping really hard at the end of flight one.
It really cracks the sky open
The SK3 1600KV is holding up really well. Very happy with that motor.
The nanotech 25C 6S3000 turned out to be a good choice. It fits and balances out with the servo on the tailboom.
Next flights will be with my second Gaui. Stretched flybarred 520mm. Its ready to go tomorrow
Old 10-21-2012, 04:58 PM   #18
PTcaflyer
...Beautiful!
Not a thing wrong with that one! I could hear the "Grin" in you audio!
PT
AMA 953414
