Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50 > Titan X50
Titan X50 Thunder Tiger Titan X50 Helicopters
Old 09-08-2012, 06:37 PM   #1
Adam F
Default Help help , tail issue
Did my first flight on the x50T today , I had to auto down after a min. or so because the tail rod disconnected from the servo horn , ther seems to be bad vibration on the tail anytime I am half stick or below . Above half stick the vibration is gone or is a lot less , alll the tail rod holders came loss also . Please help
Adam F is offline        Reply With Quote
Old 09-08-2012, 06:38 PM   #2
Adam F
The tail servo is mounted on th tail
Old 09-11-2012, 03:58 PM   #3
crashagain
I used red thread lock on the coupler, and a drop of thick CA on each of the screws on the boom guides. Check your linkage on the servo, vibes should not be making it come loose, you may have some slop and caused it to come loose.
Sent from my HTC One X using Tapatalk 2
Trex 600E FBL....Trex700DFC...Trex700FBL
more to come.....
crashagain is online now        Reply With Quote
Old 09-15-2012, 01:57 PM   #4
KouDy
I used blue threadlock on the grubs going into joiner for the tail rods. I didn't need to maintain that so far after few galons of nitro...
What vibrations do you have? Horizontal or vertical (tail wag up and down or left and right?)? Or is it that your heli vibrating completely?
shelved : Titan e325 SE flybarred | Titan X50 flybarred torque tube
Futaba 10C in mode 3
KouDy is offline        Reply With Quote
