| MA Glow Miniature Aircraft Glow Helicopter Support Forum |
Looking at building a Fury 55 with a OS 55, and AR7200BX FBL. What servos and blades are you running?
Rudy - Bend OR/Houston TX We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it. |
WELL servos can go any way just depends on how much money you have
As far as blades 620s are where it is at I run mav wc 620mm
US Army VBAR PRO GOV MA Fury 55 Whip Nitro 105 Whip Nitro (2) FOR SALE |
#3 | |
Whats a good servo for the tail if I'm using the AR7200BX? For the head I'm looking a good digital servo that wont break the bank. Shoot I ran Futaba 3001's in my Raptor 50 and it flew just fine. What tail blades are you running. Thanks
BLS451's would be perfect for cyclic. I'd use a BLS251 or a BLS256HV for the tail depending on what voltage you're running
Absolutely nothing wrong with Align/savox ds610/615's on swash , and 650/655 on the tail either .....
a 9252 works great on throttle on mine....
Peter To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Furion 6 FBL ; E,N and G Whiplash FBL ; 2 Spectra G FBL ; Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: Aeolus KME 60 , 2 Velocity 50's FBL; few 500's.. All BeastX ; guided by XPS . |
#6 |
I know several guys having good luck with the DS610s on the Fury 55.
I personally ran BLS451's, they worked very well also. I'd recommend either the BLS251 or BLS256HV as said above for the tail though.
Team Miniature Aircraft USA Team HeliWholesaler, Team Byron Fuel's, Team Thunder Power, Team Scorpion -Darrick |
#7 |
I just finished a setup for a buddy with DS 610s all the way around. Everything fit like a glove.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Goblin 700, Vbar Silver - Trex 700 V2, Vbar - Trex 700DFC, Vbar Silver - Gaui X7, Vbar Silver Trex600EFL Pro, Vbar - Trex 600 ESP, Vbar - Trex 500 ESP, SK 720 - DJI 550, GPS |
