Old 09-19-2012, 09:48 AM   #1
McCollister911
Default Jive 120 and scorpion backup guard
Has anyone tried this setup yet. It's a 500mah 2s lipo that outputs 5v incase of a bec shutdown. Sounds like a good alternative to nimh packs and only weighs 38gr. Has a peak of 10 amps which is comparable to the best nimh/nicd packs. Looks better too. Does anyone see an issue or possible issues this could have running in place of the buffer?
McCollister911 is online now        Reply With Quote
Old 09-19-2012, 06:19 PM   #2
desertstalker
No reason it wouldnt work, but you need to charge it separately.
-DX8
Old 09-22-2012, 04:07 PM   #3
Dr.Ben
The only downside to it, and they even warn you in its instructions, is it is yet another lipo for your fleet that should not be kept at full charge when not in use.
Ben Minor
Dr.Ben is offline        Reply With Quote
Old 09-23-2012, 06:24 PM   #4
desertstalker
Ben Minor
Stupid really, they should have used a LiFe pack.
-DX8
Old 09-29-2012, 09:47 PM   #5
Dr.Ben
I'm sure they were going for the lightest weight possible, but I would have gladly given up just a little to have it use a LiFe.
Ben Minor
Old 10-11-2012, 12:23 PM   #6
czynot
which LiFe pack is good to use?
Genace LiFe look like only 1C constant and 10C bust.
http://www.hobbypartz.com/98p-life-1c-1100-2s1p.html
What LiFe packs would you guys recommend. Looking for something light weight.
czynot is online now        Reply With Quote
Old 10-11-2012, 06:45 PM   #7
desertstalker
You cant use a LiFe pack with a Jive, the BEC voltage is too low. If you want a buffer pack it needs to be 4cell Ni.
The Kosmic can use LiFe, you just need to set the BEC to the right voltage (IIRC 7.2V).
-DX8
Old 10-11-2012, 10:08 PM   #8
czynot
Anyone can suggest a backup pack that is light and not lipo? I dont want lipo. I dont fly often enough to use lipo.
Old 10-11-2012, 10:31 PM   #9
CACN
I use these as a buffer pack to my Helijive 120. 4 AAA 800mah Sanyo eneloop.
http://store.batteriesamerica.com/sa...lenotinus.aspx
Henseleit TDR, Helijive 120HV, HC-3SX, HKIII 4035 560KV
Minicopter Diabolo, Helijive 120HV, AR7200BX, Xera 4530 500KV
Align Trex 550, Beastx, 600MX
Hirobo SRB Quark
CACN is offline        Reply With Quote
Old 10-12-2012, 01:22 PM   #10
Magneto
I dont think the scorp backup is a good idea on a K product after you add a switch and this device you are opening yourself up to failure if anything goes wrong with the pack or the device it could spike, burn or put a load on the bec and it will shut down to protect it self or destroy it, The best thing you can do for a back up is a fromeco DC up no switches or batteries and will give you enough juice for an auto the same as any backup or buffer.
Magneto is online now        Reply With Quote
Old 10-13-2012, 07:10 AM   #11
Greg Alderman
I believe this is what Magneto is talking about from Fromeco....I plan on getting a couple to try out soon.
http://www.fromeco.org/Products/05FRCDCUPM2/
Greg Alderman
Manager, Prestige RC
866-441-5537 Ext 802
Greg Alderman is offline        Reply With Quote
Old 10-16-2012, 07:12 AM   #12
mrparadox
I run the Scorpion backupguard with my jive 80HV.
Works great. And happy i had it.
(don't forget to switch it on ofcourse)
Lost one battery in flight Avant aurora duo a velcron failure and i could autorotate it safely! without Backupguard i would be completely set back for control. Because al the eletcornics are powered by the jive on the 2 main lipo's!
So works great in my opinion
Ofcourse a normal 4 cell bufferpack is also an option. But thsi one is small and has an on and off switch + some led what can telle you if you have to put it on the charger.
mrparadox is offline        Reply With Quote
Old 12-22-2012, 10:18 AM   #13
Carapau
Location: God's own county. Ay oop lad, tek care lambs ont road
Guys, just be careful about the DC UP. I have one and it doesn't hold a charge long enough to do an auto on. I reckon I get about 5-10 secs use of it before my Vbar turns off and that is whilst static on a table- you will get a lot less from it if airborne and your FBL unit is making constant corrections. What the DC UP is good for is for maintaining a constant min voltage. For example, my Fusion had 2 back to back horrific crashes caused by my Align servos producing back EMFs as I understood it, the DC UP would have prevented it.
Rush 750, Vbar, 9188, BLS157HV, Kosmik 160, 4525 Ult
Fusion 50, Vbar, 9188/80s, Helijive & Quantum 4135 motor,
Mini Protos DS95s/95i, Ice Lite 50, mini v
Trex 450 Pro DS95/95i, Mini V, RJX head, Ice 50 Lite, 6s 2221-2010 DX18
Carapau is offline        Reply With Quote
