| nano CP X Blade nano CP X Helicopters Information and Help |
#61 |
![]() IMG_1145 by Skidsteer16, on Flickr ![]() IMG_1146 by Skidsteer16, on Flickr ![]() IMG_1147 by Skidsteer16, on Flickr ![]() IMG_1148 by Skidsteer16, on Flickr |
#62 |
Nano CPX,HK250SR,450x,TREX500e,DX8 |
#63 |
This is Dr. Dremels mCPx paper canopy template. I shrunk it to 80%, but regrettably I cannot use it for other than shelf queening on the Nano. The lower pins cannot reach the canopy (too short). And when you put the canopy well into the upper ones, the servo links rub the canopy. Looks cool though!
Blade 2x nCPx Mild B/L, 2x mCPx dual B/L HP06V2, mCPx HP05S, 300X stockish, 300X Lynx/RKH/Wicked/Turnigy, 450X iKON, 6S T-Rex 450 V2, T-Rex 700E 3G BD3SX, Spektrum DX6i & DX8, Phoenix sim. 5 foamies. Way too many RC cars. Way WAY too little time! Last edited by SHYguy; 10-22-2012 at 03:00 AM.. Reason: bored |
#64 |
I did hidden grommets. See blog post for idea.
http://www.hacksmods.com/2012/09/nano-cp-x-mtdr-canopy/ Piece of scrap plastic from packaging. Make a hole and put the grommet in. Then put the velcro piece. The velcro strips that comes with the EFlite 150mAh batteries are perfect. Thin, low profile and lightweight. Otherwise, it should be easy to extend the pins. |
#65 |
Yeah, I've seen this on you blog, great idea
But it would still not be perfect, ideally you want the rear to sweep in together. If you do that the links cannot clear. So I guess we'd need a design specifically for the Nano. After all the stock canopy is more "ball shaped" vs. the oval one for the mCPx Instead I ordered those V911 canopys you recommended in your blog!
Blade 2x nCPx Mild B/L, 2x mCPx dual B/L HP06V2, mCPx HP05S, 300X stockish, 300X Lynx/RKH/Wicked/Turnigy, 450X iKON, 6S T-Rex 450 V2, T-Rex 700E 3G BD3SX, Spektrum DX6i & DX8, Phoenix sim. 5 foamies. Way too many RC cars. Way WAY too little time! |
#66 | |
Edge Rotorblades Thor/Voltz Batteries 450 Pro V-Bar 130X |
#67 |
Oui oui, c'est correct monsieur!
#68 | |
Sorry to hear that itīs not fitting correctly, but maybe itīs because itīs just a scaled down version of the mcpx template? I made a msrx template a while back which I adapted a little further than resizing: http://www.helifreak.com/showpost.ph...&postcount=473 So perhaps you have better luck with this one. As I have no Nano I canīt test it myself. Regards Dremel
2x MCPX I Mini Protos I Protos I DX8 |
#69 |
Thx! Very happy for a 1st attempt
No Nano!!!??? >> get one! Having so much more 3D progress with this one vs. the mCPx!Thx, I might try that mSRx template! Nice skids btw, self made? Oh, and it seemed like the colours got a little paler when I sized down the mCPx template - is that normal? (since it's not a vectorized graphic) I did it like this: -clear package tape on both sides -used bits of the same tape for assembly -Shoe Goo on the inside to seal the "seams" -clear auto paint on the outside Some slow curing but stable stuff for mounting the pieces would have been awesome... (no tabs)
#70 |
Well the Nano - time will tell if this sweet little bird fits into my fleet. I recently purchased a second mcpx and a Protos 500, so I have "binders full of helicopters" already
The skids for the mcpx/msrx in the above link are indeed self-made. http://www.helifreak.com/showpost.ph...90&postcount=9 The pale colour of canopy prints is almost certainly related to printer settings. Colour does not fade just because of resizing. Maybe wrong paper or too low quality selected? Happy flying Dremel
#71 |
Dunno, but the full size ones came out a bit darker. Done on a laser printer, std. paper. Nevermind, still looks good
I think with your skills you should do a Goblin paper canopy... and McLaren of course ![]() The skids... genious!!! ![]()
#72 |
I always wondered if Blade would start doing more colors that are not the norm so much -- soon. Greens, oranges etc... I mean make 3 for each heli - I know it's expensive maybe but still.
Tot his day on release if you look the 300x had the best choices from stock for canopy's. Here is my first nano though - I posted this when it first came out somewhere ![]()
MCX2MSRMSRXMCPXv2120SR NANOCPX130X300X450X MCPXBL500X |
#73 |
Stock Nano with yellow tail rotor with black bands painted on.
To match body color and to aid in visibility -- the yellow tips make a nice yellow circle when it spins. |
#74 |
Blade MCPX BL Rakon MCPX BL Rakon MCPX V1 Rakon NCPX-TDR, DX7. Rakon Rep. |
#75 |
Nano and 130x
Aaron TRex 500DFC-TRex 450DFC-500x-450x-130x-MCPX BL-MCPX HP06BL- NanoCPX- DX8 Flight therapy.. When Im in the air, I let my problems BLOW away. I found Bliss, high in the sky! |
#76 |
#77 |
Finally stuck it to the ceiling, this little guy got me inverted!
| mSR - mQx - Nano CPx - mCPx V2 + HP05s XP10A ESC - 130x #1 HP08s - 130x #2 stock - 300x - 450x - Phoenix Sim | |
#78 |
Here is my nano with His two brothers. The one on the right is 3s he is the big the brother of the group
Be blessed Isaac Sent from my Galaxy Nexus using Tapatalk 2
Jesus Rep all over, Team Outrage USA Rep Orange Power To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. O Fusion 50, BL mcpx ultra, 700e, trex 450 pro all FBL 3g, vbar 5.1(blk), 3g, kds ebar GOD BLESS |
#79 |
Got my "nanner" yesterday for screwing around at work. It was used and needed a canopy so I fitted a Genius cp canopy and yellow kbdd mcpx skids. I cut a section out of the top "rails" to make it fit a little better and then re-attached them with heat-shrink. They fit great and really hug the battery now. Tried to set 0 pitch at mid stick which is hard to do on this little guy for some reason. I still have a tiny bit of + pitch at mid stick. Guess I'll have to resort to sub-trims. I also had a bad left drift even with the swash tilted to the right. Had to use sub-trim to fix that as well.
Team Newb Walkera Mini cp - hp06v2, hp02t, custom fet esc's, 550's Blade 130X - hp08s, lots of bling; Blade 130X - ta955, xp12a Compass Warp 360 - CC ice lite 50, MKS DS92A+, iKon |
#80 |
The white on the skids helps with visibility, though it does tend to flake off, lol.
